Xbox 360 Wireless Controller Buttons Replacement
Brett Hartt
Brett Hartt and 5 other contributors
Last updated on June 19, 2024
15 minutes
Moderate
Introduction
Go to step 1
Repair or replace faulty buttons on your Xbox 360 wireless controller.
Parts
Tools
Show more…
  1. Xbox 360 Wireless Controller Buttons Replacement, Battery: step 1, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement, Battery: step 1, image 2 of 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Buttons Replacement, Rear Case: step 2, image 1 of 1
    Tool used on this step:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Buttons Replacement: step 3, image 1 of 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Buttons Replacement: step 4, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement: step 4, image 2 of 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Buttons Replacement: step 5, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement: step 5, image 2 of 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Buttons Replacement: step 6, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement: step 6, image 2 of 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: step 7, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: step 7, image 2 of 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Buttons Replacement: step 8, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement: step 8, image 2 of 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Buttons Replacement, Logic Board: step 9, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement, Logic Board: step 9, image 2 of 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Buttons Replacement, Buttons: step 10, image 1 of 1
    • Remove the rubber pad from the back of the input buttons.
  11. Xbox 360 Wireless Controller Buttons Replacement: step 11, image 1 of 2 Xbox 360 Wireless Controller Buttons Replacement: step 11, image 2 of 2
    • Using a pair of tweezers, remove the buttons from the front case.
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
  12. Xbox 360 Wireless Controller Buttons Replacement: step 12, image 1 of 1
    • Using a pair of tweezers, lift the home button's LED ring out of the front case of the controller.
    • All of the buttons have tabs that correspond to slots in the front case. This prevents buttons from being placed in the incorrect position or orientation.
64 other people completed this guide.
Brett Hartt
129,851 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
119 Members
19,481 Guides authored
3 Comments
Hello I have had an Xbox for about 1-2years and everything has been working fine until the A button on one of my controllers stopped working I don't think it has gunk or anything because I can press it down and it comes back up just that when I press it in screen nothing happens but the other buttons work fine
Saul Escalon - Reply
Thank you for the teardown! My cat has just vomitted on my joystick…. I could have cleaned it now! I appreciate it , thanks…
Nathan St-Onge - Reply
Has anyone ever replaced the spring contacts in the logic board???
BJ Robbins - Reply
Past 24 Hours: 10
Past 7 Days: 80
Past 30 Days: 257
All Time: 73,242
