Xbox Intec 7.2" Color Game Screen Disassembly
  1. Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: step 1, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: step 1, image 2 of 2
    • Top shell is held in place with 4 screws and 6 retaining tabs
    • Remove 2 rubber pads to uncover 2 hidden screws
    • Remove 4 #1 screws
  2. Xbox Intec 7.2" Color Game Screen Disassembly: step 2, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 2, image 2 of 2
    • Take a spudger and disengage the 6 retaining tabs
    • This will be the most time-consuming step. Be patient and take your time.
    • You will hear an audible pop when disengaging the tabs.
    • Remove top housing
  3. Xbox Intec 7.2" Color Game Screen Disassembly: step 3, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 3, image 2 of 2
    • Remove 2 #1 screws
    • Disconnect 4 wire harnesses
  4. Xbox Intec 7.2" Color Game Screen Disassembly: step 4, image 1 of 3 Xbox Intec 7.2" Color Game Screen Disassembly: step 4, image 2 of 3 Xbox Intec 7.2" Color Game Screen Disassembly: step 4, image 3 of 3
    • Disconnect speaker header
    • It's not necessary to remove the speakers from the housing unless you need to.
    • Disconnect header if speakers need to be removed. Otherwise, this will be done in the next step.
    • Remove 8 #1 screws
  5. Xbox Intec 7.2" Color Game Screen Disassembly: step 5, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 5, image 2 of 2
    • Disconnect 2 headers
    • Lift wires over retaining posts
  6. Xbox Intec 7.2" Color Game Screen Disassembly: step 6, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 6, image 2 of 2
    • Grab the edges of the board and lift up
    • Don't attempt to fully remove the board from the unit yet
    • Disconnect last header
  7. Xbox Intec 7.2" Color Game Screen Disassembly: step 7, image 1 of 1
    • It's not necessary to remove the screen from the housing unless you need to.
    • Remove 4 #1 screws to remove screen
  8. Xbox Intec 7.2" Color Game Screen Disassembly: step 8, image 1 of 2 Xbox Intec 7.2" Color Game Screen Disassembly: step 8, image 2 of 2
    • Lift up on tab
    • Remove 3 #1 screws
    • Grab the edges and lift the board up
  9. Xbox Intec 7.2" Color Game Screen Disassembly: step 9, image 1 of 1
    • Feed wires through the hinge enough to remove board from unit
    • These 4 headers are soldered directly to the board
    • If this board needs to be entirely removed, feed the wires all the way through the hinge.
Navy Vet 2015
7,350 Reputation
15 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 47
All Time: 249
