Xbox One Wireless Controller 1697 Thumbstick Replacement
  1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: step 1, image 1 of 1
    • Slide the battery pack cover toward the top of the controller to remove it.
    • Remove batteries.
  2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 2, image 1 of 2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 2, image 2 of 2
    • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
    • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
    • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
    • Repeat this process for both side handles.
  3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 3, image 1 of 2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 3, image 2 of 2
    • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label.
    • You can punch a hole using a screwdriver or peel off the label.
  4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 4, image 1 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 4, image 2 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 4, image 3 of 3
    • Remove the back plate.
  5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 5, image 1 of 1
    • Remove the faceplate
  6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 6, image 1 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 6, image 2 of 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: step 6, image 3 of 3
    • Select the thumbstick that you want to replace and pull it off its pole.
27 other people completed this guide.
Emely
839 Reputation
1 Guide authored
USF Tampa, Team S9-G1, Remmell Fall 2017 Member of USF Tampa, Team S9-G1, Remmell Fall 2017
USFT-REMMELL-F17S9G1
4 Members
14 Guides authored
One Comment
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - Reply
Past 24 Hours: 10
Past 7 Days: 49
Past 30 Days: 191
All Time: 22,470
