creative ac adapter model maf115160th
  1. creative ac adapter model maf115160th, panel: step 1, image 1 of 2 creative ac adapter model maf115160th, panel: step 1, image 2 of 2
    • panel view
  2. creative ac adapter model maf115160th, inside view: step 2, image 1 of 1
    • solder the new thermal fuse (or bridge) between the left and the middle contact (in the picture there is just a bridge -above the red tape-... (had no thermal fuse at hand at first...)
  3. creative ac adapter model maf115160th: step 3, image 1 of 1
    • found one 85c in a used li-ion-pack... be VERY careful when soldering NOT to exceed the max. temp meanwhile--- suggest to put a final layer of tape around to get better contact to the coil -where the heat is coming from in case of overload-
close the lid and add eg thermo-glue or just use the soldering-iron and make the housing melt along the pits
8 other people completed this guide.
biopilz
465 Reputation
2 Guides authored
3 Comments
My A300 speaker adapters has blown I need to get a new one
Sakhile Lloyd - Reply
Can you show me of this Adapter diagram. The middle line in primary is broken but i don’t know how to connect to which leg
Tien - Reply
Can I use the lead line instead of fuse to connected
Tien - Reply
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 77
All Time: 7,719
