iFixit Adhesive Remover Preparation
  1. iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: step 1, image 1 of 2 iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: step 1, image 2 of 2
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  2. iFixit Adhesive Remover Preparation: step 2, image 1 of 3 iFixit Adhesive Remover Preparation: step 2, image 2 of 3 iFixit Adhesive Remover Preparation: step 2, image 3 of 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
Finish Line
10 other people completed this guide.
Arthur Shi
254,543 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 63
Past 30 Days: 374
All Time: 15,011
