iPad 3 Wi-Fi Power & Volume Button Replacement.
  1. iPad 3 Wi-Fi Power & Volume Button Replacement., iOpener Heating: step 1, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement., iOpener Heating: step 1, image 2 of 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 2, image 1 of 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100ËšC (212ËšF).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 3, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 3 Wi-Fi Power & Volume Button Replacement., Alternate iOpener heating method: step 4, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement., Alternate iOpener heating method: step 4, image 2 of 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel: step 5, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel: step 5, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel: step 5, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 6, image 1 of 1
    Tool used on this step:
    Safety Glasses
    $3.19
    Buy
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
  7. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 7, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 7, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 7, image 3 of 3
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
  8. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 8, image 1 of 1
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
  9. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 9, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 9, image 2 of 2
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
  10. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 10, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 10, image 2 of 2
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
  11. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 11, image 1 of 1
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
  12. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 12, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 12, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 12, image 3 of 3
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  13. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 13, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 13, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 13, image 3 of 3
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  14. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 14, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 14, image 2 of 2
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  15. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 15, image 1 of 1
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
  16. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 16, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 16, image 2 of 2
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
  17. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 17, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 17, image 2 of 2
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
  18. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 18, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 18, image 2 of 2
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
  19. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 19, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 19, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 19, image 3 of 3
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  20. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 20, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 20, image 2 of 2
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
  21. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 21, image 1 of 1
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  22. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 22, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 22, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 22, image 3 of 3
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
  23. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 23, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 23, image 2 of 2
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  24. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 24, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 24, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 24, image 3 of 3
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  25. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 25, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 25, image 2 of 2
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  26. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 26, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 26, image 2 of 2
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
  27. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 27, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 27, image 2 of 2
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
  28. iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel Assembly: step 28, image 1 of 1
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
  29. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 29, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 29, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 29, image 3 of 3
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
  30. iPad 3 Wi-Fi Power & Volume Button Replacement., LCD: step 30, image 1 of 1
    • Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
  31. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 31, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 31, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 31, image 3 of 3
    Buy
    • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
  32. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 32, image 1 of 1
    • Without touching the front of the LCD, lift the LCD off the front panel.
  33. iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel Assembly: step 33, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel Assembly: step 33, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement., Front Panel Assembly: step 33, image 3 of 3
    • If necessary, peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
    • Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
  34. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 34, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 34, image 2 of 2
    • Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable.
    • Very carefully pull the digitizer ribbon cable straight out of its sockets on the logic board.
  35. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 35, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 35, image 2 of 2
    • Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
  36. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 36, image 1 of 1
    • Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
    • Remove the front panel from the iPad.
  37. iPad 3 Wi-Fi Power & Volume Button Replacement., Headphone Jack Cable: step 37, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement., Headphone Jack Cable: step 37, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement., Headphone Jack Cable: step 37, image 3 of 3
    • Peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
    • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
  38. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 38, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 38, image 2 of 2
    • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
    • Pull the headphone jack assembly cable straight out of its socket on the logic board.
  39. iPad 3 Wi-Fi Power & Volume Button Replacement., Headphone Jack Assembly: step 39, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement., Headphone Jack Assembly: step 39, image 2 of 2
    • Peel back and remove the adhesive tape covering the headphone jack assembly.
  40. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 40, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 40, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 40, image 3 of 3
    • Using the flat end of a spudger, pry the front-facing camera connector off of its socket on the headphone jack assembly.
    • Slide the spudger to the right, releasing the adhesive holding down the camera cable.
  41. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 41, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 41, image 2 of 2
    • Using the tip of a spudger, flip up the retaining flap on the microphone cable ZIF connector.
  42. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 42, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 42, image 2 of 2
    • Insert the tip of the spudger underneath the microphone ribbon cable, removing it from its ZIF connector.
    • Slide the spudger to the left, releasing the adhesive holding the microphone ribbon cable to the headphone jack assembly.
  43. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 43, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 43, image 2 of 2
    • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
    • Remove the volume button ribbon cable from its ZIF connector.
  44. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 44, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 44, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 44, image 3 of 3
    • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.0 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
    • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  45. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 45, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 45, image 2 of 2
    • Gently peel the headphone jack assembly ribbon cable up from the foam pad in the top left of the rear case.
    • If necessary, use the flat end of a spudger to loosen the adhesive securing the ribbon cable to the foam.
  46. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 46, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 46, image 2 of 2
    • Grasping the headphone jack assembly with both hands, pull the assembly from the iPad, minding any cables that may get caught.
  47. iPad 3 Wi-Fi Power & Volume Button Replacement., Power & Volume Button Assembly: step 47, image 1 of 1
    • Remove the following screws securing the power & volume button cable to the aluminum frame:
    • Two 5.5mm Phillips #0
    • One 2.6 mm Phillips #0
    • These screws are angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  48. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 48, image 1 of 1
    • Remove the piece of plastic covering the volume buttons.
  49. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 49, image 1 of 1
    • Remove the single 2.6 mm Phillips #00 screw holding the volume button frame to the aluminum frame.
    • This screw is angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  50. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 50, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 50, image 2 of 2
    • Wedge the edge of a plastic opening tool underneath the sleep/wake sensor, being careful to not damage the fragile cable.
    • Move the plastic opening tool around the sensor, releasing the adhesive.
  51. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 51, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 51, image 2 of 2
    • Continue sliding the plastic opening tool underneath the power & volume cables, releasing the adhesive.
  52. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 52, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 52, image 2 of 2
    • Using the tip of a spudger, release the adhesive underneath the volume button branch of the ribbon cable.
  53. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 53, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 53, image 2 of 2
    • Continue sliding the tip of the spudger toward the top of the iPad, releasing the adhesive.
  54. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 54, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 54, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 54, image 3 of 3
    • With the tip of the spudger still underneath the ribbon cable, gently lift the power button out of its socket in the aluminum frame.
  55. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 55, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 55, image 2 of 2
    • Holding the power & volume button cable with with both hands, carefully pull the volume buttons and lock switch from their sockets in the aluminum frame.
    • Lift and remove the power & volume button cable out of the rear aluminum case.
  56. iPad 3 Wi-Fi Power & Volume Button Replacement., Power & Volume Buttons: step 56, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement., Power & Volume Buttons: step 56, image 2 of 2
    • Wedge the tip of the plastic opening tool underneath the top side of the power button.
    • Pry the topside of the power button up off the power button bracket.
  57. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 57, image 1 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 57, image 2 of 3 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 57, image 3 of 3
    • Repeat the previous step on the underside of the power button.
    • Lift and remove the power button bracket from the power & volume button assembly.
  58. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 58, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 58, image 2 of 2
    • Wedge the tip of the plastic opening tool underneath the top side of the rotation lock/mute switch.
    • Slide the plastic opening tool downwards to pry the topside of the rotation lock/mute switch from its bracket.
  59. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 59, image 1 of 2 iPad 3 Wi-Fi Power & Volume Button Replacement.: step 59, image 2 of 2
    • Insert the tip of the plastic opening tool underneath the top volume rocker and pry upwards to separate it from the volume buttons bracket.
    • Repeat the procedure to separate the bottom volume rocker from the volume buttons bracket.
  60. iPad 3 Wi-Fi Power & Volume Button Replacement.: step 60, image 1 of 1
    • Lift and remove the power & volume button ribbon cable.
8 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 10,406
