iPad 3G Metal Display Clips Replacement
  1. iPad 3G Metal Display Clips Replacement, Display Assembly: step 1, image 1 of 3 iPad 3G Metal Display Clips Replacement, Display Assembly: step 1, image 2 of 3 iPad 3G Metal Display Clips Replacement, Display Assembly: step 1, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad 3G Metal Display Clips Replacement: step 2, image 1 of 2 iPad 3G Metal Display Clips Replacement: step 2, image 2 of 2
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. iPad 3G Metal Display Clips Replacement: step 3, image 1 of 2 iPad 3G Metal Display Clips Replacement: step 3, image 2 of 2
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. iPad 3G Metal Display Clips Replacement: step 4, image 1 of 2 iPad 3G Metal Display Clips Replacement: step 4, image 2 of 2
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. iPad 3G Metal Display Clips Replacement: step 5, image 1 of 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. iPad 3G Metal Display Clips Replacement: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. iPad 3G Metal Display Clips Replacement: step 7, image 1 of 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. iPad 3G Metal Display Clips Replacement: step 8, image 1 of 3 iPad 3G Metal Display Clips Replacement: step 8, image 2 of 3 iPad 3G Metal Display Clips Replacement: step 8, image 3 of 3
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. iPad 3G Metal Display Clips Replacement: step 9, image 1 of 1
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  10. iPad 3G Metal Display Clips Replacement: step 10, image 1 of 2 iPad 3G Metal Display Clips Replacement: step 10, image 2 of 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  11. iPad 3G Metal Display Clips Replacement: step 11, image 1 of 1
    • Remove the display assembly from the rear panel assembly.
  12. iPad 3G Metal Display Clips Replacement, Metal Display Clips: step 12, image 1 of 1
    • During the display assembly removal process, it is highly likely that the metal clips around the perimeter of the of the display assembly will break.
    • To replace a broken clip, first remove the T5 Torx screw securing the broken base of the clip to the display assembly.
    • Place a new clip on the positioning pins molded into the display frame, and reinstall the T5 Torx screw to secure the two pieces together.
    • Repeat this process for any other broken clips around your display assembly.
9 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 24
All Time: 14,045
