iPhone X Disassembly
Video Overview
  1. iPhone X Disassembly, Turn off the phone and remove SIM Card: step 1, image 1 of 2 iPhone X Disassembly, Turn off the phone and remove SIM Card: step 1, image 2 of 2
    • Press the wake button and volume down button to turn off the phone.
  2. iPhone X Disassembly, Open the phone: step 2, image 1 of 3 iPhone X Disassembly, Open the phone: step 2, image 2 of 3 iPhone X Disassembly, Open the phone: step 2, image 3 of 3
    • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will allow the phone to be opened more easily.
  3. iPhone X Disassembly, Remove the iPhone X OLED screen: step 3, image 1 of 3 iPhone X Disassembly, Remove the iPhone X OLED screen: step 3, image 2 of 3 iPhone X Disassembly, Remove the iPhone X OLED screen: step 3, image 3 of 3
    • Undo 5 screws shown in the picture below with a tripoint #Y000 screwdriver
    • These screws are all different sized so keep track of where they go
    • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
  4. iPhone X Disassembly, Remove the ear speaker: step 4, image 1 of 2 iPhone X Disassembly, Remove the ear speaker: step 4, image 2 of 2
    • Undo 3 Y000 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
  5. iPhone X Disassembly, Remove rear-facing cameras.: step 5, image 1 of 1
    • Remove the 2 Phillips #PH00 screws and remove the metal plate, release the rear cameras connectors.
    • These screws are also different sizes
  6. iPhone X Disassembly, Remove motherboard.: step 6, image 1 of 2 iPhone X Disassembly, Remove motherboard.: step 6, image 2 of 2
    • Release all connectors on the motherboard with a spudger
    • Undo 3 Phillips #PH00 screws on the mother board then we can take out the mother board.
  7. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: step 7, image 1 of 3 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: step 7, image 2 of 3 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: step 7, image 3 of 3
    • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
    • Remove the loud speaker and the taptic engine.
  8. iPhone X Disassembly, Remove battery: step 8, image 1 of 2 iPhone X Disassembly, Remove battery: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
  9. iPhone X Disassembly, Remove front-facing camera: step 9, image 1 of 2 iPhone X Disassembly, Remove front-facing camera: step 9, image 2 of 2
    • Heating the front facing camera with a heat gun will make it easily to be removed
  10. iPhone X Disassembly, Remove the charging port and antenna: step 10, image 1 of 3 iPhone X Disassembly, Remove the charging port and antenna: step 10, image 2 of 3 iPhone X Disassembly, Remove the charging port and antenna: step 10, image 3 of 3
    • Release 4 screws on the frame shown in the picture
    • Heating the charging port flex cable then we can remove it easily
  11. iPhone X Disassembly, Remove Wi-Fi antenna: step 11, image 1 of 3 iPhone X Disassembly, Remove Wi-Fi antenna: step 11, image 2 of 3 iPhone X Disassembly, Remove Wi-Fi antenna: step 11, image 3 of 3
    • Release 7 screws on the Wi-Fi flex cable
    • Heating the flex cable with a heat gun make it easier to be removed
  12. iPhone X Disassembly, Remove power button flex cable: step 12, image 1 of 3 iPhone X Disassembly, Remove power button flex cable: step 12, image 2 of 3 iPhone X Disassembly, Remove power button flex cable: step 12, image 3 of 3
    • Release 3 screws on the power button
    • Heating the flex cable with a heat gun then it can be removed easily
129 other people completed this guide.
Mandy
9,518 Reputation
9 Guides authored
25 Comments
excellent guide!!!
Andy Lee - Reply
The iPhone X assemble video: https://youtu.be/E5jyuxgpE_g
Mandy - Reply
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Arnoud - Reply
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Mandy -
Past 24 Hours: 23
Past 7 Days: 230
Past 30 Days: 1,260
All Time: 209,755
