iPod Shuffle 3rd Generation Logic Board Replacement
  1. iPod Shuffle 3rd Generation Logic Board Replacement, Rear Case: step 1, image 1 of 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Logic Board Replacement: step 2, image 1 of 2 iPod Shuffle 3rd Generation Logic Board Replacement: step 2, image 2 of 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Logic Board Replacement: step 3, image 1 of 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Logic Board Replacement: step 4, image 1 of 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Logic Board Replacement, Logic Board: step 5, image 1 of 1
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Logic Board Replacement: step 6, image 1 of 1
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Logic Board Replacement: step 7, image 1 of 1
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
2 other people completed this guide.
Matthew Newsom
39,544 Reputation
67 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 6,430
