iRobot Roomba 770 Battery Replacement
  1. iRobot Roomba 770 Battery Replacement, Battery: step 1, image 1 of 2 iRobot Roomba 770 Battery Replacement, Battery: step 1, image 2 of 2
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Battery Replacement: step 2, image 1 of 2 iRobot Roomba 770 Battery Replacement: step 2, image 2 of 2
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
3 other people completed this guide.
Andrew Horvath
444 Reputation
3 Guides authored
Cal Poly, Team 15-3, Livingston Fall 2016 Member of Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 3,890
