iRobot Roomba Battery Replacement
  1. iRobot Roomba Battery Replacement, Loosen the edge brush screw: step 1, image 1 of 1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Battery Replacement, Remove the edge brush: step 2, image 1 of 2 iRobot Roomba Battery Replacement, Remove the edge brush: step 2, image 2 of 2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
  3. iRobot Roomba Battery Replacement, Loosen the bottom screws: step 3, image 1 of 2 iRobot Roomba Battery Replacement, Loosen the bottom screws: step 3, image 2 of 2
    • Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
    • Those screws are captive screws and therefore not removable.
  4. iRobot Roomba Battery Replacement, Remove the bottom plate: step 4, image 1 of 3 iRobot Roomba Battery Replacement, Remove the bottom plate: step 4, image 2 of 3 iRobot Roomba Battery Replacement, Remove the bottom plate: step 4, image 3 of 3
    • Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
  5. iRobot Roomba Battery Replacement, Unlatch and remove the battery: step 5, image 1 of 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: step 5, image 2 of 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: step 5, image 3 of 3
    • Use your finger to bend the plastic clip and unlatch the battery.
    • Grab the battery with your hand and lift it straight up from inside its recess to remove it.
Tobias Isakeit
118,079 Reputation
189 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 297
All Time: 3,007
