This teardown is not a repair guide. To repair your CANDY CON Wireless Controller, use our service manual.
  1. CANDY CON Wireless Controller Teardown, Remove the faceplate: step 1, image 1 of 2 CANDY CON Wireless Controller Teardown, Remove the faceplate: step 1, image 2 of 2
    • Locate the indentation on the bottom of the controller
    • Pull the faceplate off using a fingernail or spudger
  2. CANDY CON Wireless Controller Teardown, Remove Joysticks and D-pad: step 2, image 1 of 2 CANDY CON Wireless Controller Teardown, Remove Joysticks and D-pad: step 2, image 2 of 2
    • Remove both joysticks and the D-pad by carefully pulling up
  3. CANDY CON Wireless Controller Teardown, Begin opening the base controller: step 3, image 1 of 3 CANDY CON Wireless Controller Teardown, Begin opening the base controller: step 3, image 2 of 3 CANDY CON Wireless Controller Teardown, Begin opening the base controller: step 3, image 3 of 3
    • Remove 8 Phillips screws with a Philips #1 screwdriver
    • Pry open the two main pieces by pulling up on the edges of the controller
  4. CANDY CON Wireless Controller Teardown, Finish opening the base controller: step 4, image 1 of 2 CANDY CON Wireless Controller Teardown, Finish opening the base controller: step 4, image 2 of 2
    • Separate the controller by flipping it on its face and then prying up near the bottom buttons
  5. CANDY CON Wireless Controller Teardown, Unplug the battery: step 5, image 1 of 1
    • Unplug the battery using a spudger tool
  6. CANDY CON Wireless Controller Teardown, Unscrew the mainboard: step 6, image 1 of 1
    • Unscrew the 2 Phillips #1 screws securing the mainboard to the controller housing
  7. CANDY CON Wireless Controller Teardown, Remove the mainboard and haptic motors: step 7, image 1 of 3 CANDY CON Wireless Controller Teardown, Remove the mainboard and haptic motors: step 7, image 2 of 3 CANDY CON Wireless Controller Teardown, Remove the mainboard and haptic motors: step 7, image 3 of 3
    • Carefully remove the mainboard and attached haptic motors by pulling it up from the bottom and then top
    • Be careful removing the haptic motors to ensure the wires do not break
  8. CANDY CON Wireless Controller Teardown, Teardown Complete!: step 8, image 1 of 2 CANDY CON Wireless Controller Teardown, Teardown Complete!: step 8, image 2 of 2
    • All buttons are keyed so they can only go in the exact spot they belong
  9. CANDY CON Wireless Controller Teardown, Reassembly tips: step 9, image 1 of 3 CANDY CON Wireless Controller Teardown, Reassembly tips: step 9, image 2 of 3 CANDY CON Wireless Controller Teardown, Reassembly tips: step 9, image 3 of 3
    • Follow the teardown guide in reverse to reassemble the controller
    • When reassembling the controller align the bottom buttons first and then work on the charging port side
    • Test all the buttons before or right after screwing in the mainboard
    • The D-pad has an arrow on the top that should point up (towards the arrow on the base controller)
Roger
229 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 84
All Time: 84
