This teardown is not a repair guide. To repair your Compaq iPaq Pocket PC 3765, use our service manual.
  1. Compaq iPaq Pocket PC 3765 Teardown, Compaq iPaq Pocket PC 3765 Teardown: step 1, image 1 of 1
    • an original ipaq from compaq not hp
    • the teardown is realatively simple (PS: simply is not always easy)
  2. Compaq iPaq Pocket PC 3765 Teardown: step 2, image 1 of 3 Compaq iPaq Pocket PC 3765 Teardown: step 2, image 2 of 3 Compaq iPaq Pocket PC 3765 Teardown: step 2, image 3 of 3
    • There are four torx screws here
  3. Compaq iPaq Pocket PC 3765 Teardown: step 3, image 1 of 3 Compaq iPaq Pocket PC 3765 Teardown: step 3, image 2 of 3 Compaq iPaq Pocket PC 3765 Teardown: step 3, image 3 of 3
    • Gently pry around the edges to release the cover
    • The battery is glued to the back cover be careful not to damage the fragile ribbon cable
    • fold the back under the front panel and carefully remove the battery connector
  4. Compaq iPaq Pocket PC 3765 Teardown: step 4, image 1 of 2 Compaq iPaq Pocket PC 3765 Teardown: step 4, image 2 of 2
    • x
  5. Compaq iPaq Pocket PC 3765 Teardown: step 5, image 1 of 2 Compaq iPaq Pocket PC 3765 Teardown: step 5, image 2 of 2
    • Disconnect the backlight
    • from the inverter
    • here is an Htc branded processor
    • be sure to pop up the black wire
    • remove the stylus ejector
  6. Compaq iPaq Pocket PC 3765 Teardown: step 6, image 1 of 1
    • Gently pull on the top face while lifting the logic board (will require some force)
    • Be careful of the black wire running along the board
    • Disconnect the screen and digitizer cables being careful not to damage the cable or connector
  7. Compaq iPaq Pocket PC 3765 Teardown: step 7, image 1 of 1
    • two Intel flash chips
  8. Compaq iPaq Pocket PC 3765 Teardown: step 8, image 1 of 3 Compaq iPaq Pocket PC 3765 Teardown: step 8, image 2 of 3 Compaq iPaq Pocket PC 3765 Teardown: step 8, image 3 of 3
    • again putting pressure on the top panel lift the display out of the case
  9. Compaq iPaq Pocket PC 3765 Teardown: step 9, image 1 of 1
    • an htc branded control board
    • (funny I thought it said compaq on the front?)
  10. Compaq iPaq Pocket PC 3765 Teardown: step 10, image 1 of 2 Compaq iPaq Pocket PC 3765 Teardown: step 10, image 2 of 2
    • The final product (destroyed that is)
    • I used NO anti-static precautions, reassembled the device and after finaly getting the video cable to lock in it worked fine
    • PS: the touch panel worked But when i fixed the video cable i knocked it loose and didnt realize it and now i have to fix it (sigh)
josh9623
149 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 3,822
