This teardown is not a repair guide. To repair your Fnatic STREAK65, use our service manual.
  1. Fnatic STREAK65 Teardown, Disconnect the USB-C cable: step 1, image 1 of 2 Fnatic STREAK65 Teardown, Disconnect the USB-C cable: step 1, image 2 of 2
    • Disconnect the USB-C cable that powers the keyboard
  2. Fnatic STREAK65 Teardown, Remove the keycaps: step 2, image 1 of 2 Fnatic STREAK65 Teardown, Remove the keycaps: step 2, image 2 of 2
    • Remove the keyboard keycaps either with special tools or simply with your fingers
  3. Fnatic STREAK65 Teardown, Remove the 13 Phillips #00 screws: step 3, image 1 of 1
    • Unscrew the 13 Phillips #00 screws that secure the upper cover to the lower body
  4. Fnatic STREAK65 Teardown, Remove the light bar: step 4, image 1 of 2 Fnatic STREAK65 Teardown, Remove the light bar: step 4, image 2 of 2
    • Remove the light bar with a nail or a spudger
  5. Fnatic STREAK65 Teardown, Remove the upper cover: step 5, image 1 of 2 Fnatic STREAK65 Teardown, Remove the upper cover: step 5, image 2 of 2
    • Remove the top cover to free the motherboard with the soldered switches
  6. Fnatic STREAK65 Teardown, Reassemble everything: step 6, image 1 of 2 Fnatic STREAK65 Teardown, Reassemble everything: step 6, image 2 of 2
    • Follow the instructions in reverse order to reassemble the keyboard.
    • P.S You can replace one of your keyboard keys with the awesome official keycap from iFixit
Andrea Alfani
7,593 Reputation
5 Guides authored
Kid fixers Member of Kid fixers
Community
157 Members
294 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 106
All Time: 657
