This teardown is not a repair guide. To repair your Desktop PC, use our service manual.
  1. Microdigital TK 85 Teardown, The TK 85 case and connectors: step 1, image 1 of 3 Microdigital TK 85 Teardown, The TK 85 case and connectors: step 1, image 2 of 3 Microdigital TK 85 Teardown, The TK 85 case and connectors: step 1, image 3 of 3
    • 9V DC = Nomo P2 power supply
    • ExpansĂ£o = Expansion connector 2x23 edge pins.
    • Joystick = Joystick connector DIN-6-07M.
    • Mic = audio output for a datacorder.
    • Ear = Audio input for a datacorder.
    • Video = RF chanel 3 VHF output.
  2. Microdigital TK 85 Teardown, Inside the TK85: step 2, image 1 of 3 Microdigital TK 85 Teardown, Inside the TK85: step 2, image 2 of 3 Microdigital TK 85 Teardown, Inside the TK85: step 2, image 3 of 3
    • Open it carefully because of the 2 keyboard flat cables.
    • Those flat cables are very problematic
  3. Microdigital TK 85 Teardown, Keyboard removed: step 3, image 1 of 2 Microdigital TK 85 Teardown, Keyboard removed: step 3, image 2 of 2
    • The upper part of the case is the keyboard, but the keyboard itself is not removable.
    • The lower part of the case is just a plastic part.
  4. Microdigital TK 85 Teardown, The circuit board: step 4, image 1 of 2 Microdigital TK 85 Teardown, The circuit board: step 4, image 2 of 2
    • The circuit board is a very compact circuit board with dual layer traks.
  5. Microdigital TK 85 Teardown, Rom and Ram: step 5, image 1 of 2 Microdigital TK 85 Teardown, Rom and Ram: step 5, image 2 of 2
    • MM2716Q-5 => 16Kb Eprom
    • 52164KSF/N => 64kb Rom ? It is a custom Microdigital Rom compatible with the NMC2764.
    • MCM4116BC-15 => 8 x 16,348 bits Ram = 16Kb Ram
  6. Microdigital TK 85 Teardown, The RF generator: step 6, image 1 of 3 Microdigital TK 85 Teardown, The RF generator: step 6, image 2 of 3 Microdigital TK 85 Teardown, The RF generator: step 6, image 3 of 3
    • Just a RF Chanel 3 VHF modulator.
  7. Microdigital TK 85 Teardown, Microchips identification: step 7, image 1 of 2 Microdigital TK 85 Teardown, Microchips identification: step 7, image 2 of 2
    • Microprocessor
    • Rom
    • Eprom
    • Ram
    • Oscilator 555. Works as an PWM 5 Volt power supply to the micropocessor.
    • Spare space for an audio integrated circuit. It was never implemented in producion in this model.
    • Voltage regulator 7805
    • Frequency divider = 6,5Mhz used for video and 3,25Mhz used for actual clock.
Vinicius Rodrigues Bellini
956 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 849
