This teardown is not a repair guide. To repair your Nintendo 64 Controller, use our service manual.
  1. Nintendo 64 Controller Teardown, Nintendo 64 Controller Teardown: step 1, image 1 of 3 Nintendo 64 Controller Teardown, Nintendo 64 Controller Teardown: step 1, image 2 of 3 Nintendo 64 Controller Teardown, Nintendo 64 Controller Teardown: step 1, image 3 of 3
    • Behold the glorious retro controller face, then forget about it because you will flip the controller for the rest of the teardown.
    • Use the size #1 Philips to remove the 7 screws on the back of the controller.
    • Use the size #0 Philips to remove the smaller screws in the controller pak slot.
  2. Nintendo 64 Controller Teardown: step 2, image 1 of 1
    • Remove the back plate. You can now see the:
    • Power Input
    • Game Pak Slot
    • Trigger Button Assemblies
    • Z Button Assembly
    • Joystick Module
  3. Nintendo 64 Controller Teardown: step 3, image 1 of 1
    • Using a spudger or similar tool, carefully pry the Z button assembly from the joystick module.
    • Remove the 3 size #0 screws holding in the joystick module.
    • Remove the joystick cable from the main board.
  4. Nintendo 64 Controller Teardown: step 4, image 1 of 2 Nintendo 64 Controller Teardown: step 4, image 2 of 2
    • Remove the joystick module.
    • This particular module is a third party replacement. Yours may look different.
  5. Nintendo 64 Controller Teardown: step 5, image 1 of 2 Nintendo 64 Controller Teardown: step 5, image 2 of 2
    • Remove the main board and trigger assemblies.
    • Your controller is now fully disassembled!
  6. Nintendo 64 Controller Teardown: step 6, image 1 of 1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
Ian
1,474 Reputation
2 Guides authored
Kid fixers Member of Kid fixers
Community
165 Members
302 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 289
All Time: 13,734
