This teardown is not a repair guide. To repair your Numworks Graphing Calculator, use our service manual.
  1. Numworks Graphing Calculator Teardown, Numworks Graphing Calculator Teardown: step 1, image 1 of 1
    • Peel away the six rubber foots on the back of the calculator using your fingernails.
  2. Numworks Graphing Calculator Teardown: step 2, image 1 of 1
    • Using a Torx T6 (or TR6) screwdriver, remove all six screws.
  3. Numworks Graphing Calculator Teardown: step 3, image 1 of 2 Numworks Graphing Calculator Teardown: step 3, image 2 of 2
    • Carefully peel the two case parts away from each other, taking turns on each side disconnecting one at a time for all eight clips. The third row from the bottom up is more secure than the others. DO NOT JERK CASE APART, THERE IS A BATTERY CONNECTOR TO REMOVE instead, slowly open the case 180 degrees with the back facing you.
  4. Numworks Graphing Calculator Teardown: step 4, image 1 of 1
    • Carefully wiggle the battery connector until it slides easily loose. You have now finished removing the Numworks Graphing Calculator's case.
JamesPi
134 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 163
All Time: 215
