This teardown is not a repair guide. To repair your Oculus Rift CV1, use our service manual.
  1. Oculus Rift Constellation Teardown, Oculus Rift Constellation Teardown: step 1, image 1 of 3 Oculus Rift Constellation Teardown, Oculus Rift Constellation Teardown: step 1, image 2 of 3 Oculus Rift Constellation Teardown, Oculus Rift Constellation Teardown: step 1, image 3 of 3
    • We don't know too much about the Constellation sensor itself, but here are some specs:
    • Infrared sensor
    • Sweet stand
    • Standard USB 3.0 cable
    • But look how far we've come—from ugly webcam, to cute lil' Pixar lamp!
  2. Oculus Rift Constellation Teardown: step 2, image 1 of 3 Oculus Rift Constellation Teardown: step 2, image 2 of 3 Oculus Rift Constellation Teardown: step 2, image 3 of 3
    Tool used on this step:
    Jimmy
    $7.95
    Buy
    • Separation of the crew capsule complete!
    • We locked our keys in the Constellation, so we're gonna try to Jimmy the door open.
    • And with just a few plastic clips holding the back panel in place, it pops off with in a snap.
    • And look! Promising screws... that go nowhere.
  3. Oculus Rift Constellation Teardown: step 3, image 1 of 3 Oculus Rift Constellation Teardown: step 3, image 2 of 3 Oculus Rift Constellation Teardown: step 3, image 3 of 3
    • Let's try to smoke it out the other end. iOpener to full!
    • Hats off to the smallest suction cup we could find! With one good tug, the modestly adhered visible-light filter gives way to reveal the eye of the IR camera.
    • Because the Constellation sensor's job is to track LEDs that only give off infrared light, any other wavelength is just noise, making it harder for it to operate. This filter blocks out everything but IR, making it easier to pick out the LEDs.
    • Without the visible light filter, the sensor would see what our fancy IR camera sees—and would have a hard time picking out just the pattern of LEDs to determine the Rift's position and orientation in space.
    • Never missing a chance to play with our IR camera, we hop outside and stack on the Constellation's visible-light filter to get a glimpse at the stars—or downtown San Luis Obispo.
    • The visible light filter restricts the light coming in to the image sensor to the IR spectrum, meaning the IR LEDs on the headband will shine bright like a diamond stars.
    • Even without the filter, there's plenty of infrared to see outside. That's why ordinary cameras need a filter, so they see what you see!
  4. Oculus Rift Constellation Teardown: step 5, image 1 of 3 Oculus Rift Constellation Teardown: step 5, image 2 of 3 Oculus Rift Constellation Teardown: step 5, image 3 of 3
    • Okay, we asked nicely twice, but the components still won't budge—time for some aggressive negotiations.
    • The Constellation's lone eye seems to stare pleadingly. Let's hope it doesn't start singing "Daisy Bell."
    • We shuck the (well-rotary-tooled) outer casing and find an inner shell secured with some fiercely-glued screws.
    • Whipping that away in short order, all that's left are the real guts of this sensor.
    • Teardown Update: Whoops! According to Oculus, you can shuck the IR sensor's cowling by pulling the stand hardware off. When we got our second unit we took some channellocks and a vice grip to it and were able to free the hardware from the camera assembly.
    • Still, some disassembly instructions would have been nice!
  5. Oculus Rift Constellation Teardown: step 6, image 1 of 3 Oculus Rift Constellation Teardown: step 6, image 2 of 3 Oculus Rift Constellation Teardown: step 6, image 3 of 3
    • First out: that USB 3.0 Cable.
    • Despite being embedded in the heart of the Constellation, this is a standard USB 3.0 peripheral connector, swappable in the event of catastrophic failure. (Though we're at a loss as to how you'd put everything back together).
    • We remove the camera from the board, and the heat sink from the camera, and then the lens from the image sensor, and well, here we are.
  6. Oculus Rift Constellation Teardown: step 7, image 1 of 2 Oculus Rift Constellation Teardown: step 7, image 2 of 2
    • We're at the end of the line—let's take a peek at the silicon!
    • EtronTech eSP770U Webcam Controller
    • Nordic Semiconductor nRF51822 Bluetooth Smart and 2.4GHz proprietary SoC (also found in the Oculus Rift Headset)
    • Macronix MX25L1006E 1 Mb serial flash memory
    • STMicroelectronics BALF-NRF01D3 50 Ω Bluetooth balun
    • ON Semiconductor NC7SB3157L6X SPDT analog switch (likely)
    • ON Semiconductor NCP1529MUTBG adjustable 1 A DC-DC step down converter
    • ON Semiconductor ESD7004 4-ch. TVS diode array
  7. Oculus Rift Constellation Teardown: step 8, image 1 of 2 Oculus Rift Constellation Teardown: step 8, image 2 of 2
    • Oculus Rift Constellation Sensor Repairability Score: 7 out of 10 (10 is easiest to repair)
    • Stand and visible light filter are removable and can be replaced if damaged.
    • All main components (motherboard, camera, lens, and filter) are discrete and modular, making repairs fairly low cost and straightforward.
    • The USB cable plugs directly into the motherboard and can be swapped out quickly.
    • Strong adhesive holds the visible light filter in place.
    • Stand hardware takes significant force to remove and is not obviously removable without instructions.
Evan Noronha
223,653 Reputation
168 Guides authored
17 Comments
But how do they assemble the thing together in the factory if you can't undo it without causing permanent damage?
Honam1021 - Reply
Because it's meant to be bought again.
jvelez -
Glue. It's easy to glue things together. Hard to unglue them.
Chris Cline -
Ultrasonic welding, not glue.
William Gates -
Turns out you can pull it apart without cutting it open https://twitter.com/PalmerLuckey/status/...
karlww -
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 73
All Time: 42,391
