Video Overview
This teardown is not a repair guide. To repair your Shoe, use our service manual.
  1. Pleaser Flashdance Shoe Teardown, Pleaser Flashdance Shoe Teardown: step 1, image 1 of 2 Pleaser Flashdance Shoe Teardown, Pleaser Flashdance Shoe Teardown: step 1, image 2 of 2
    • I had already pulled apart the first shoe before filming.
    • When I went to pull apart the second one, I found that the last time the sole had been repaired, the bonding worked really really well.
    • This made it very difficult to pull the shoe apart. So instead I'll show the shoe I had already pulled apart.
  2. Pleaser Flashdance Shoe Teardown: step 2, image 1 of 3 Pleaser Flashdance Shoe Teardown: step 2, image 2 of 3 Pleaser Flashdance Shoe Teardown: step 2, image 3 of 3
    • Before getting to the electronics the common spots for these shoes to fail is:
    • The sole starts to lift from the platform,
    • The suede on the front of the toe rips and peels,
    • The ankle strap tears,
    • The toe strap tears.
  3. Pleaser Flashdance Shoe Teardown: step 3, image 1 of 3 Pleaser Flashdance Shoe Teardown: step 3, image 2 of 3 Pleaser Flashdance Shoe Teardown: step 3, image 3 of 3
    • The shoe works by charging with a micro USB next to the power button on the shank of the shoe.
    • The power button also cycles the colours and modes.
    • To protect the electronics, the shoes come with a warning to avoid excessive banging and moister.
  4. Pleaser Flashdance Shoe Teardown: step 4, image 1 of 3 Pleaser Flashdance Shoe Teardown: step 4, image 2 of 3 Pleaser Flashdance Shoe Teardown: step 4, image 3 of 3
    • The RGB LED light strip is glued to the platform.
    • The strip ran down the shank of the shoe and then wrapped around the shell containing the battery and board.
    • This board shell in held in place under the sole in the box of the platform. The plastic box was sealed with glue.
    • Warning: It was difficult to remove the glue that sealed the shell. The battery could have been damaged when removing it from the case.
  5. Pleaser Flashdance Shoe Teardown: step 5, image 1 of 3 Pleaser Flashdance Shoe Teardown: step 5, image 2 of 3 Pleaser Flashdance Shoe Teardown: step 5, image 3 of 3
    • The shell cracked, especially at the center, there's a clear indent from the chip in the middle of the board.
    • Unfortunately, after taking this shoe apart, while I was trying to take detail shots, the wire that connects to the button and USB charge port broke.
  6. Pleaser Flashdance Shoe Teardown: step 6, image 1 of 3 Pleaser Flashdance Shoe Teardown: step 6, image 2 of 3 Pleaser Flashdance Shoe Teardown: step 6, image 3 of 3
    • I also found some burning where the battery is soldered to the board and the battery is a little bit of a spicy pillow.
  7. Pleaser Flashdance Shoe Teardown: step 7, image 1 of 1
    • All the pieces.
Stashtree
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 931
