This teardown is not a repair guide. To repair your Samsung Galaxy Ace, use our service manual.
  1. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: step 1, image 1 of 3 Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: step 1, image 2 of 3 Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: step 1, image 3 of 3
    • Rotate your Phone.
    • Remove the plastic battery door.
    • Remove battery.
    • Unscrew all 7 screws so that the cover can be removed.
  2. Samsung Galaxy Ace Teardown: step 2, image 1 of 3 Samsung Galaxy Ace Teardown: step 2, image 2 of 3 Samsung Galaxy Ace Teardown: step 2, image 3 of 3
    • With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
    • Make sure your Micro SD card is removed from the device Micro SD card slot.
    • Disconnect the microphone using your fingers, be careful not to do too much pressure.
  3. Samsung Galaxy Ace Teardown: step 3, image 1 of 3 Samsung Galaxy Ace Teardown: step 3, image 2 of 3 Samsung Galaxy Ace Teardown: step 3, image 3 of 3
    • Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
    • Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
  4. Samsung Galaxy Ace Teardown: step 4, image 1 of 3 Samsung Galaxy Ace Teardown: step 4, image 2 of 3 Samsung Galaxy Ace Teardown: step 4, image 3 of 3
    • Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
    • Now with a plastic tool you can disconnect the LCD connector.
  5. Samsung Galaxy Ace Teardown: step 5, image 1 of 3 Samsung Galaxy Ace Teardown: step 5, image 2 of 3 Samsung Galaxy Ace Teardown: step 5, image 3 of 3
    • Remove logic board
    • Disconnect speaker and camera with a plastic tool.
  6. Samsung Galaxy Ace Teardown: step 6, image 1 of 3 Samsung Galaxy Ace Teardown: step 6, image 2 of 3 Samsung Galaxy Ace Teardown: step 6, image 3 of 3
    • Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
    • After lifting the connector of the touch screen (black tab), lift the cable carefully!
  7. Samsung Galaxy Ace Teardown: step 7, image 1 of 3 Samsung Galaxy Ace Teardown: step 7, image 2 of 3 Samsung Galaxy Ace Teardown: step 7, image 3 of 3
    • Press the home button to remove it. (This is not fixed,no material).
    • Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
    • Remove it.
  8. Samsung Galaxy Ace Teardown: step 8, image 1 of 1
    • Disassembly is finished! To assemble, follow the guide from the end point to the initial.
AndreaBaglione
3,912 Reputation
3 Guides authored
3 Comments
Very helpful, I had to open it all up as shown in photo to get my stuck SIM cards out. Thanks.
Yash J - Reply
My ace s5830 cant sharging i change ic charge and battary and also can t charging why !
Jaafar Fakih - Reply
Maybe motherboard or cable is dead?
Paul Richard -
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 16,319
