This teardown is not a repair guide. To repair your Super Nintendo Entertainment System Controller, use our service manual.
  1. Super Nintendo Entertainment System Controller Teardown, Super Nintendo Entertainment System Controller Teardown: step 1, image 1 of 1
    • It's your classic Super Nintendo controller.
    • Notably, it's a wired controller (same as most of the controllers of the era), and has a very simple layout.
    • The design is often called a "dogbone", due to the shape of the lower part.
  2. Super Nintendo Entertainment System Controller Teardown: step 2, image 1 of 1
    • Nintendo, unlike the Control Deck counterpart, did not use custom screws in the controller, therefore it's very easy to open and clean.
    • We remove the 5 Phillips screws on the back of the controller.
  3. Super Nintendo Entertainment System Controller Teardown: step 3, image 1 of 2 Super Nintendo Entertainment System Controller Teardown: step 3, image 2 of 2
    • Open... the... controller.
  4. Super Nintendo Entertainment System Controller Teardown: step 4, image 1 of 3 Super Nintendo Entertainment System Controller Teardown: step 4, image 2 of 3 Super Nintendo Entertainment System Controller Teardown: step 4, image 3 of 3
    • There are two metal rods that we have to take care of before removing the rest, otherwise they might get lost.
    • We remove the two shoulder buttons.
  5. Super Nintendo Entertainment System Controller Teardown: step 5, image 1 of 3 Super Nintendo Entertainment System Controller Teardown: step 5, image 2 of 3 Super Nintendo Entertainment System Controller Teardown: step 5, image 3 of 3
    • Now we can get onto the board! We first remove the cable from the slack poles.
    • After that, it's only a matter of lifting the board out.
  6. Super Nintendo Entertainment System Controller Teardown: step 6, image 1 of 3 Super Nintendo Entertainment System Controller Teardown: step 6, image 2 of 3 Super Nintendo Entertainment System Controller Teardown: step 6, image 3 of 3
    • Onto the rubber pads that represent the buttons, we'll have to remove those too.
    • Many of these older controllers might have delicate rubber pads, they should be handled carefully.
  7. Super Nintendo Entertainment System Controller Teardown: step 7, image 1 of 3 Super Nintendo Entertainment System Controller Teardown: step 7, image 2 of 3 Super Nintendo Entertainment System Controller Teardown: step 7, image 3 of 3
    • Inching closer, we get to the shoulder button's rubber pads.
    • We can finally remove the remaining plastic buttons from the D-Pad and face button areas.
  8. Super Nintendo Entertainment System Controller Teardown: step 8, image 1 of 3 Super Nintendo Entertainment System Controller Teardown: step 8, image 2 of 3 Super Nintendo Entertainment System Controller Teardown: step 8, image 3 of 3
    • The board itself has the controller cable attached, we can remove that too.
    • Not all controllers have a removable cable. Some models, such as the SNS-102, have soldered-on cables.
    • We make sure to pull away from the connector, and not up! It might be a little difficult depending on how long it's been attached.
  9. Super Nintendo Entertainment System Controller Teardown: step 9, image 1 of 3 Super Nintendo Entertainment System Controller Teardown: step 9, image 2 of 3 Super Nintendo Entertainment System Controller Teardown: step 9, image 3 of 3
    • The SNES Controller board features a number of pads as well as a chip.
    • The chip on the board is a 12-bit shift register, used to multiplex all the button signals on the controller into a more budget-friendly connector.
  10. Super Nintendo Entertainment System Controller Teardown: step 10, image 1 of 1
    • Finally, we can see all the innards that make this little controller work.
    • Maybe we should play a few rounds of Super Mario World...
Foxlet
601 Reputation
3 Guides authored
2 Comments
What is the repair ability score ?
logan - Reply
what size screws are used?
Elizabeth Ziriada - Reply
Past 24 Hours: 6
Past 7 Days: 49
Past 30 Days: 215
All Time: 14,709
