This teardown is not a repair guide. To repair your Suzuki FA50 Moped, use our service manual.
  1. Suzuki FA50 Moped Teardown, Suzuki FA50 Moped Teardown: step 1, image 1 of 1
    • There's no rage against this machine.
    • Looks great, except it doesn't run.
    • Its 50 cc engine lets me go downhill at almost 28 MPH when it does run. Uphills, not so much. Depending on the hill (and my head start), I may or may not have to walk it up.
    • The seat advertises "185 LB max." In the USA??
    • The above weight limit can be used in a "Yo mamma" joke. Note that I said can be, and not should be.
  2. Suzuki FA50 Moped Teardown: step 2, image 1 of 1
    • Safety first. Disconnect the battery and store it in a safe place.
    • The battery's readily accessible underneath the seat.
  3. Suzuki FA50 Moped Teardown: step 3, image 1 of 1
    • In retrospect I figured out i that I didn't need to remove the exhaust cover, but what the heck... When in Rome, right?
  4. Suzuki FA50 Moped Teardown: step 4, image 1 of 2 Suzuki FA50 Moped Teardown: step 4, image 2 of 2
    • Took off the air intake box.
    • That's contractor-grade 3M packing tape holding the airbox together. Only the best for my moped.
  5. Suzuki FA50 Moped Teardown: step 5, image 1 of 1
    • I went to the other side of the bike and removed the carb/oil pump protective cover.
  6. Suzuki FA50 Moped Teardown: step 6, image 1 of 1
    • The foot rest came off next, in order to gain access to the engine and spark plug.
  7. Suzuki FA50 Moped Teardown: step 7, image 1 of 1
    • While down there, I unplugged the spark plug cover.
  8. Suzuki FA50 Moped Teardown: step 8, image 1 of 2 Suzuki FA50 Moped Teardown: step 8, image 2 of 2
    • I then proceeded to access the wiring underneath the gas tank.
    • The wires needed to be disconnected in order to remove the frame away from the engine/crankshaft.
    • First I removed the protective brace on top of the oil/gas tanks using a 10 mm socket wrench.
  9. Suzuki FA50 Moped Teardown: step 9, image 1 of 1
    • I had to take off both oil and gas caps in order to remove the plastic protective cover.
  10. Suzuki FA50 Moped Teardown: step 10, image 1 of 2 Suzuki FA50 Moped Teardown: step 10, image 2 of 2
    • I set aside the fuel tank and bam! -- the wires were ready to be disconnected.
    • The wires must have been minding their own business since '84... Separating them was quite a challenge. Thankfully they had those round connectors on them, so I didn't have to solder or crimp anything when reassembling the moped.
  11. Suzuki FA50 Moped Teardown: step 11, image 1 of 2 Suzuki FA50 Moped Teardown: step 11, image 2 of 2
    • I then unplugged the emergency fuel valve .
    • The valve should remain in the "On" position while working on the moped.
  12. Suzuki FA50 Moped Teardown: step 12, image 1 of 1
    • I paused for a minute to enjoy a cold cup of Diet Coke, and to drain all the 2-cycle oil...
    • I got the Goliath "freezer" mug in Six Flags Magic Mountain about 6-7 years ago. Best investment I ever made, aside from marrying the wife. It's the gift that keeps on giving!
    • Ikea bowls come in quite handy. Turns out there was enough 2-cycle oil to fill the entire bowl to the brim!
  13. Suzuki FA50 Moped Teardown: step 13, image 1 of 2 Suzuki FA50 Moped Teardown: step 13, image 2 of 2
    • I had a difficult time figuring out what I was doing in these pictures. According to the manual, I was removing the oil pump cover and oil hose.
  14. Suzuki FA50 Moped Teardown: step 14, image 1 of 2 Suzuki FA50 Moped Teardown: step 14, image 2 of 2
    • Unscrewing the smaller valve, which I believe to be the carburetor choke cable.
    • My culprit resides beneath the carburetor top cover. Even though I reassembled the moped, I'll have to investigate the throttle cable going into the carburetor.
  15. Suzuki FA50 Moped Teardown: step 15, image 1 of 3 Suzuki FA50 Moped Teardown: step 15, image 2 of 3 Suzuki FA50 Moped Teardown: step 15, image 3 of 3
    • Rear brake gets disconnected next. The cable needs to be free since the brake lever will come off with the rest of the frame.
  16. Suzuki FA50 Moped Teardown: step 16, image 1 of 1
    • The rear spring gets unsprung using a 14 mm socket wrench.
    • Disconnecting the spring may be potentially dangerous, as it may be under tension.
    • Nothing crazy happened when I disconnected it, however.
  17. Suzuki FA50 Moped Teardown: step 17, image 1 of 2 Suzuki FA50 Moped Teardown: step 17, image 2 of 2
    • Finally, the large frame screw can be removed. This is the last piece of hardware holding the frame to the rear wheel / engine.
    • I had to use two 17 mm wrenches -- a socket on one side, and a ratcheting wrench on the other.
  18. Suzuki FA50 Moped Teardown: step 18, image 1 of 2 Suzuki FA50 Moped Teardown: step 18, image 2 of 2
    • And just like that, the frame comes off!
  19. Suzuki FA50 Moped Teardown: step 19, image 1 of 2 Suzuki FA50 Moped Teardown: step 19, image 2 of 2
    • A 12 mm and 10 mm hex socket take care of the muffler.
  20. Suzuki FA50 Moped Teardown: step 20, image 1 of 1
    • Now on to the engine.
    • Spark plug comes out with a strong flick of the wrist.
    • The plug looked like it was the original one that came with the moped. Dirty dirty!
  21. Suzuki FA50 Moped Teardown: step 21, image 1 of 2 Suzuki FA50 Moped Teardown: step 21, image 2 of 2
    • I continued by removing the front part of the engine using a 10 mm socket wrench. I found plenty of buildup inside.
  22. Suzuki FA50 Moped Teardown: step 22, image 1 of 2 Suzuki FA50 Moped Teardown: step 22, image 2 of 2
    • I wanted to see what a "flywheel magneto" looked like, so I decided to remove this cover. I figured anything named after an X-Man is worth a look...
    • I stripped the Phillips originals while taking the cover off. I replaced them with appropriately-sized 20 mm hex-head screws.
    • This is a 65 mm replacement I ordered online, along with news seals and stuff.
  23. Suzuki FA50 Moped Teardown: step 23, image 1 of 3 Suzuki FA50 Moped Teardown: step 23, image 2 of 3 Suzuki FA50 Moped Teardown: step 23, image 3 of 3
    • Some shots of the engine...
  24. Suzuki FA50 Moped Teardown: step 24, image 1 of 2 Suzuki FA50 Moped Teardown: step 24, image 2 of 2
    • The reed valve comes right off. You can see the engine internals from the hole -- cool!
    • I was careful not to accidentaly put any crap inside the engine. I figured the Shuttle wouldn't run well on dirt and Cheerios.
  25. Suzuki FA50 Moped Teardown: step 25, image 1 of 3 Suzuki FA50 Moped Teardown: step 25, image 2 of 3 Suzuki FA50 Moped Teardown: step 25, image 3 of 3
    • The reed valve is a very important part of the moped, according to the service manual. The metal bars have to be bent a certain way, and other stuff.
  26. Suzuki FA50 Moped Teardown: step 26, image 1 of 1
    • I had quite a difficult time shooting a "final layout" shot. I gave up after 5-10 pictures; this one was the best of the bunch.
    • That's it! Hope you enjoyed my teardown!
8 Comments
I am looking for some close up pictures of where exactly the wiring harness runs, I am putting a shuttle back together that I did not take apart, both front and rear photos would be helpful
eric - Reply
I am looking for a manual how to replace my spark plug of my Suzuki FA50. Can you help me?
Tiest Ryckoort - Reply
Do you know if the crank case would be the same for a 84 as it would be for a 83 im purchasing a new crank case for my 83 but found a 84 crank case for cheap
Jacob Rogers - Reply
Hello everyone my Suzuki FA 50 has a rubber line plugged exactly under the carburetor but i have no idea where other ends goes on the top
Cam anyone help?? Here is my email Gemini54302@aol.com
Thank you
Antonio - Reply
that’s like A overflow it does not go anywhere except for the ground that it rides on!
mqaz1 - Reply
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 71
All Time: 75,165
