This teardown is not a repair guide. To repair your Texas Instruments TI BA II Plus, use our service manual.
  1. Texas Instruments TI BA II Plus Teardown, Texas Instruments TI BA II Plus Teardown: step 1, image 1 of 1
    • The BA II Plus Professional calculator.
  2. Texas Instruments TI BA II Plus Teardown: step 2, image 1 of 1
    • Remove the battery cover by sliding it out.
  3. Texas Instruments TI BA II Plus Teardown: step 3, image 1 of 1
    • Firstly on the back cover, remove the small sticky soft cushioning material covering the recess with the screws in it. 4 of them in total. Unscrew them.
  4. Texas Instruments TI BA II Plus Teardown: step 4, image 1 of 1
    • Use a flathead screwdriver to gently part the bottom and top cover at the hinge on the top.
  5. Texas Instruments TI BA II Plus Teardown: step 5, image 1 of 1
    • Removing the back cover to reveal the foil, unscrew the 4 screws holding the foil and 4 other holding the printed circuit board to the front cover.
  6. Texas Instruments TI BA II Plus Teardown: step 6, image 1 of 1
    • Remove the foil. Ensure all screws are off.
  7. Texas Instruments TI BA II Plus Teardown: step 7, image 1 of 1
    • This must separate the front cover from the board. Remove the board and turn it over to view the front side with a soft black cushion cover over a smooth shinny mesh.
  8. Texas Instruments TI BA II Plus Teardown: step 8, image 1 of 1
    • The keys should fall out of the front cover when you turn it over as well. Thats it!!!
VSP
101 Reputation
1 Guide authored
4 Comments
Well, my TI BA II plus has a broken LCD screen which according to the customer care is not covered under the warranty. Is it possible to find a replacement LCD to replace the broken one in the calculator.
Thanks
VSP - Reply
My calculated get in water, now its not working is there any way to repair it.
ankur - Reply
Did it stopped working immediately ? Also what did u do then
Akshat S Gupta -
This is a terrific service that you are providing. It makes fixing thing so much easier. Thank you.
ROB LYTLE - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 60
All Time: 9,582
