This teardown is not a repair guide. To repair your Whelen Slimlighter Super-LED, use our service manual.
  1. Whelen Slimlighter Super-LED Teardown, Whelen Slimlighter Super-LED Teardown: step 1, image 1 of 2 Whelen Slimlighter Super-LED Teardown, Whelen Slimlighter Super-LED Teardown: step 1, image 2 of 2
    • This is Whelen's second generation Slimlighter. Whilst the first generation had multiple 5mm LED's, this generation Slimlighter has 'only' 12 TIR6 style LED's.
    • Enough chatter, let's take it apart :)
  2. Whelen Slimlighter Super-LED Teardown: step 2, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 2, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 2, image 3 of 3
    • Optionally one can first take of the suctioncup brackets. They are held in place by two Philips screws.
    • Next you can take off the retaining brackets. They are held back by a little notch that has to be lifted with a spudger. Repeat this step for the other side.
    • Once the notch is lifted pull the bracket away from the light as shown.
  3. Whelen Slimlighter Super-LED Teardown: step 3, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 3, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 3, image 3 of 3
    • Once the brackets are released the light can easily be dissasembled. Begin by lifting the diffuser lens up as shown.
    • One can also have clear lenses here, the procedure is the same.
    • Note that the lens has a similar notch on the other side, underneath the Whelen logo. Carefully pull the lens out from underneath, don't force anything or it will break.
  4. Whelen Slimlighter Super-LED Teardown: step 4, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 4, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 4, image 3 of 3
    • With the diffuser lenses removed the optics are exposed. They are not secured by anything so carefulle take them out as shown
    • Nifty little optics here, kudo's to Whelen.
    • Try activating the light now, see the differences with and without these optics
  5. Whelen Slimlighter Super-LED Teardown: step 5, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 5, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 5, image 3 of 3
    • Now you can CAREFULLY take out the LED assembly. It's attached to a metal heat dissapating bracket. CAREFUL with the wiring. Note that the bracket is retained by the plastic housing. It might need some help before it gives way.
  6. Whelen Slimlighter Super-LED Teardown: step 6, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 6, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 6, image 3 of 3
    • The wires are held back /retained by a stickon Whelen logo. The logo can easily be removed, just tear it off carefully.
  7. Whelen Slimlighter Super-LED Teardown: step 7, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 7, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 7, image 3 of 3
    • Once the Whelen logo tab is removed the light comes apart completley.
    • Take out the two metal brackets holding the light.
    • Note that one of the brackets holds (part of) the flasher assembly.
  8. Whelen Slimlighter Super-LED Teardown: step 8, image 1 of 3 Whelen Slimlighter Super-LED Teardown: step 8, image 2 of 3 Whelen Slimlighter Super-LED Teardown: step 8, image 3 of 3
    • If desired, take out the six Philips screws to remove the LED circuit board from the bracket.
    • Note that the rear circuit board is held back by the same screws.
    • The LED board can easily be replaced by any other TIR6 board, any color (as far as I could check!)
    • Note that there is cooling paste between the LED board and the bracket. Make sure you replace it.
  9. Whelen Slimlighter Super-LED Teardown: step 9, image 1 of 2 Whelen Slimlighter Super-LED Teardown: step 9, image 2 of 2
    • All done! No more steps required :)
V3nture
161 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 50
All Time: 7,839
