This teardown is not a repair guide. To repair your Microsoft Zune 80, use our service manual.
  1. Zune 80 GB Teardown, Zune 80 GB Teardown: step 1, image 1 of 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap located on top of the device.
  2. Zune 80 GB Teardown: step 2, image 1 of 1
    • There are two T4 screws under the cap. Remove both screws with a T4 screwdriver.
    • WARNING: Be careful when removing the screws since they can strip very easily.
  3. Zune 80 GB Teardown: step 3, image 1 of 2 Zune 80 GB Teardown: step 3, image 2 of 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are five clips on each side and two on the bottom.
    • WARNING: Be careful not to press the tools in too far because there are exposed cables right inside the edge of the device.
  4. Zune 80 GB Teardown: step 4, image 1 of 2 Zune 80 GB Teardown: step 4, image 2 of 2
    • Remove the silver tape from the bottom center and the top right of the device. This allows access to the hard drive and the battery.
  5. Zune 80 GB Teardown: step 5, image 1 of 3 Zune 80 GB Teardown: step 5, image 2 of 3 Zune 80 GB Teardown: step 5, image 3 of 3
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive.
    • Gently push towards the bottom of the device on the black bar until you hear a click sound. It is now disengaged from the hard drive.
    • If the cable does not come off easily, the black bar has not been un-clicked.
    • Now, gently pull the orange hard drive cable to remove it from the hard drive cable.
    • Lift the hard drive out of the device.
  6. Zune 80 GB Teardown: step 6, image 1 of 2 Zune 80 GB Teardown: step 6, image 2 of 2
    • Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
  7. Zune 80 GB Teardown: step 7, image 1 of 1
    • Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
  8. Zune 80 GB Teardown: step 8, image 1 of 3 Zune 80 GB Teardown: step 8, image 2 of 3 Zune 80 GB Teardown: step 8, image 3 of 3
    • Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
    • Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
  9. Zune 80 GB Teardown: step 9, image 1 of 1
    • The orange audio board cable is clipped in with a small black bar, like the hard drive cable.
    • Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when it disengages.
    • If the cable does not come off easily, the black bar has not been unclicked.
  10. Zune 80 GB Teardown: step 10, image 1 of 1
    • Flip the black bar to unclip the left side of the hard drive cable. You may now remove the hard drive cable.
  11. Zune 80 GB Teardown: step 11, image 1 of 2 Zune 80 GB Teardown: step 11, image 2 of 2
    • Remove the two T4 screws that hold the charging port on the bottom of the device.
    • Remove the charging port.
  12. Zune 80 GB Teardown: step 12, image 1 of 3 Zune 80 GB Teardown: step 12, image 2 of 3 Zune 80 GB Teardown: step 12, image 3 of 3
    • Remove the battery from the device with the cables still connected.
    • Carefully lift up the logic board located at the base of the Zune.
    • Unclip the orange ribbon cable in the same manner as in the previous steps.
    • Remove the logic board from the Zune, leaving the black wire connected.
  13. Zune 80 GB Teardown: step 13, image 1 of 2 Zune 80 GB Teardown: step 13, image 2 of 2
    • Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune.
    • The assembly is lightly glued to the device. Use caution, as some force will be needed, but too much force will damage the board.
    • Remove the assembly and the battery together as one unit.
  14. Zune 80 GB Teardown: step 14, image 1 of 2 Zune 80 GB Teardown: step 14, image 2 of 2
    • Gently pry the screen unit from the black, plastic front frame.
koolkid
518 Reputation
2 Guides authored
Cal Poly, Team 6-5, Maness Fall 2009 Member of Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Members
5 Guides authored
One Comment
you can do the same with Zune 120, 4, 8 and 16
PROHIBIDO EL PASO - Reply
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 57
All Time: 16,536
