This teardown is not a repair guide. To repair your iPhone 12, use our service manual.
  1. iPhone 12  Teardown, Remove the SIM: step 1, image 1 of 2 iPhone 12  Teardown, Remove the SIM: step 1, image 2 of 2
    • Remove the SIM Card tray using a SIM Card eject tool
  2. iPhone 12  Teardown, Unscrew the lower screws: step 2, image 1 of 3 iPhone 12  Teardown, Unscrew the lower screws: step 2, image 2 of 3 iPhone 12  Teardown, Unscrew the lower screws: step 2, image 3 of 3
    • Turn off the device
    • Unscrew the two 6.9 mm long Pentalobe screws.
  3. iPhone 12  Teardown, Raise the display: step 3, image 1 of 3 iPhone 12  Teardown, Raise the display: step 3, image 2 of 3 iPhone 12  Teardown, Raise the display: step 3, image 3 of 3
    • Apply a heated iOpener all around the edge of the screen to loosen the adhesive under the display.
    • Lift the display with a suction cup and insert a thin object to separate the screen from the frame.
    • Slide the fine object along the entire edge to cut the adhesive.
    • Raise the display.
  4. iPhone 12  Teardown, Disconnect the display: step 4, image 1 of 3 iPhone 12  Teardown, Disconnect the display: step 4, image 2 of 3 iPhone 12  Teardown, Disconnect the display: step 4, image 3 of 3
    • Remove the 6 Phillips # 00 screws.
    • With a spudger or with your fingernails, lift the two connectors.
    • Lift the connector underneath.
    • Disconnect the display connector.
  5. iPhone 12  Teardown, Remove the rear camera: step 5, image 1 of 3 iPhone 12  Teardown, Remove the rear camera: step 5, image 2 of 3 iPhone 12  Teardown, Remove the rear camera: step 5, image 3 of 3
    • Unscrew the 4 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the two rear camera connectors.
    • Remove the rear camera.
  6. iPhone 12  Teardown, Remove the front camera.: step 6, image 1 of 2 iPhone 12  Teardown, Remove the front camera.: step 6, image 2 of 2
    • With a spudger or fingernails to disconnect the three connectors that connect the front camera.
    • Remove the front camera.
  7. iPhone 12  Teardown, Remove the battery holder: step 7, image 1 of 2 iPhone 12  Teardown, Remove the battery holder: step 7, image 2 of 2
    • With a spudger or fingernails disconnect the battery holder connector.
    • Unscrew the 3 Phillips # 00 screws.
    • Remove the battery holder.
  8. iPhone 12  Teardown, Remove the camera flash: step 8, image 1 of 1
    • With a spudger or fingernails disconnect the rear camera flash connector.
    • Unscrew the 2 Phillips # 00 screws.
    • Remove the rear camera flash.
  9. iPhone 12  Teardown, Remove the SIM card holder: step 9, image 1 of 3 iPhone 12  Teardown, Remove the SIM card holder: step 9, image 2 of 3 iPhone 12  Teardown, Remove the SIM card holder: step 9, image 3 of 3
    • Unscrew the 2 screw holders with the suitable screwdriver.
    • With a spudger or fingernails to disconnect the SIM card holder connector.
    • Remove the SIM card holder.
  10. iPhone 12  Teardown, Remove the battery logic board: step 10, image 1 of 2 iPhone 12  Teardown, Remove the battery logic board: step 10, image 2 of 2
    • Remove the 2 Phillips # 00 screws.
    • With a spudger or fingernails disconnect the 3 battery connectors.
    • Unscrew the screw holder with a standoff screwdriver for iphone.
    • Remove the film with a spudger.
    • Attention this last step is necessary to remove the logic board.
    • Remove the logic board.
  11. iPhone 12  Teardown, Remove the speaker: step 11, image 1 of 2 iPhone 12  Teardown, Remove the speaker: step 11, image 2 of 2
    • Unscrew the 5 Phillips # 00 screws.
    • Remove the speaker.
  12. iPhone 12  Teardown, Remove the taptic engine: step 12, image 1 of 2 iPhone 12  Teardown, Remove the taptic engine: step 12, image 2 of 2
    • Remove the 2 screw holders with a standoff screwdriver for iphone
    • Remove the taptic engine connector with a spudger or fingernail.
    • Remove the taptic engine.
  13. iPhone 12  Teardown, Remove the battery: step 13, image 1 of 2 iPhone 12  Teardown, Remove the battery: step 13, image 2 of 2
    • Remove the adhesive under the battery.
    • To remove the adhesive under the battery, remove the stickers marked in red in the first photo.
    • Remove the battery.
  14. iPhone 12  Teardown, Remove the charging port: step 14, image 1 of 2 iPhone 12  Teardown, Remove the charging port: step 14, image 2 of 2
    • Unscrew 6 Phillips # 00 screws.
    • Remove the 4 screw holders with an iPhone standoff screwdriver.
    • Attention, the previous step is essential to remove the charging port.
    • Remove the charging port.
    • Be careful not to make too strong, this could damage some components.
  15. iPhone 12  Teardown: step 15, image 1 of 1
    • And here are all the components that make up the new iPhone 12.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Andrea Alfani
7,593 Reputation
5 Guides authored
Kid fixers Member of Kid fixers
Community
157 Members
294 Guides authored
4 Comments
I had problem with nfc. When it was changed. Have any solution?
Ak H - Reply
I don't see any mentioning of the microphone, Is the Microphone an integral part of the charging port harnes?
Paal Halvorsen - Reply
This guide is missing A LOT of steps
Jason Oestrike​ - Reply
This is definitely not a US iPhone 12! e careful as the antenna can tear easily and potentially ruin a motherboard.
Kyle Morrell - Reply
Past 24 Hours: 36
Past 7 Days: 325
Past 30 Days: 1,667
All Time: 28,654
