This teardown is not a repair guide. To repair your Phone Accessory, use our service manual.
  1. iPhone 5s Dock Teardown, iPhone 5s Dock Teardown: step 1, image 1 of 1
    • Today's teardown subject will be this iPhone 5s dock - it's visually similar to the other docks from the past, but with a Lightning connector instead.
    • This teardown was edited in 2016 (that means lots of 2016 references.)
    • This looks like an indented iPhone 6 dock.
  2. iPhone 5s Dock Teardown: step 2, image 1 of 3 iPhone 5s Dock Teardown: step 2, image 2 of 3 iPhone 5s Dock Teardown: step 2, image 3 of 3
    • This iPhone dock is perfectly indented to fit an iPhone 5s.
    • Some (weaker) adhesive covers the bottom and it's a simple task to take it off using a spudger, or another flat, flexible tool.
  3. iPhone 5s Dock Teardown: step 3, image 1 of 2 iPhone 5s Dock Teardown: step 3, image 2 of 2
    • Use a spudger to carefully detach the cover from the base.
  4. iPhone 5s Dock Teardown: step 4, image 1 of 3 iPhone 5s Dock Teardown: step 4, image 2 of 3 iPhone 5s Dock Teardown: step 4, image 3 of 3
    • You can now remove the two screws that secure the weight to the plastic housing.
ma4ax
53 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 36
All Time: 6,063
