Bose SoundLink Mini Troubleshooting: Fix Common Problems
The first step towards a working Bose SoundLink Mini is identifying the problem. Select one of our preferred guides below to diagnose and solve Bose SoundLink Mini common issues.
Bose SoundLink Mini Won't Turn On When Connected to Power
Wondering what to do when your Bose SoundLink Mini speaker doesn't turn on, even when you plug it into a power outlet? Try these fixes to get your Bose Bluetooth speaker working again.
Bose SoundLink Mini Won't Pair
Are you having trouble getting your SoundLink Mini to pair with another device via Bluetooth? Follow these troubleshooting steps to diagnose the issue.
Bose SoundLink Mini Won't Turn On When Using Battery
Trying to figure out what to do when your Bose SoundLink Mini doesn't run on battery power? Use these solutions to diagnose your issue.
Bose SoundLink Mini Won't Play Music
Is your SoundLink Mini refusing to play music even when it says it is paired? Try these troubleshooting tips to find the cause.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Replaced my battery, however, all LED lights are now illuminated
Bose SoundLink Mini
My SoundLink Mini isn't turning on!
Bose SoundLink Mini
My soundlink mini won't charge, the battery indicator is flashing red
Bose SoundLink Mini
Why does my bose doesn't turn on and while charging red light flashes
Bose SoundLink Mini
Will not charge, flashing red light.
Bose SoundLink Mini
Bose SoundLink Mini 1 won't turn on
Bose SoundLink Mini
The SoundLink Mini isn't playing music!
Bose SoundLink Mini
Bose SoundLink Mini 1st Gen - Original Battery# 061384 Availability
Bose SoundLink Mini
