Dyson v6 Absolute Brush Bar Won’t Turn
Arielle Sampson and 1 contributor
Last updated on
Does your Dyson v6 Absolute vacuum cleaner’s brush bar no longer rotate when the device is on? Dyson v6 Absolute vacuum cleaners are susceptible to a range of problems that can cause their brush bars to stop rotating. Check the following possible causes to identify and solve the problem.
Causes
If your vacuum cleaner’s brush bar is not turning, there may be debris preventing the roller head from operating normally in the soft roller head. Disconnect the roller head from the wand. Unlock the brush bar by using a coin to turn the dial marked with a padlock into the unlock position. Carefully remove the brush bar and remove the debris. If there is a blockage in the flat floor tool, remove debris from the base plate.
Unlock the base plate by using a coin to turn the dial marked with a padlock into the unlock position. After cleaning, refit the brush bar. Secure it by using a coin to tighten the dial marked with a padlock so that it is once again in the lock position. Replace the base plate, and secure it by using a coin to tighten the dial marked with a padlock so that it is once again in the lock position.
2
If your vacuum cleaner’s brush bar is still not turning, there may be debris preventing the roller head from operating normally in the hard roller head. Disconnect the roller head from the wand.
Unlock the brush bar by using a coin to turn the dial marked with a padlock into the unlock position. Carefully remove the brush bar from the roller head and clear any debris. Replace the brush bar back into the roller head and secure it by using a coin to tighten the dial marked with a padlock so that it is once again in the lock position.
3
If you have removed any potential clogs from the vacuum’s brush bars and they are still not turning, you may be dealing with a faulty motor. If the motor or cyclone of the Dyson v6 Absolute vacuum is not functioning properly, remove the main body of the device using the Dyson v6 Absolute Main Body Replacement Guide. Once the main body is removed, remove and replace the vacuum’s motor.
View statistics:
Past 24 Hours:
8
Past 7 Days:
32
Past 30 Days:
192
All Time:
7,044
