LG Refrigerator Troubleshooting: Fix Common Problems
The first step towards a working LG Refrigerator is identifying the problem. Select one of our preferred guides below to diagnose and solve LG Refrigerator common issues.
LG Freezer Not Freezing
Is your LG fridge cold but the freezer compartment is warm? Follow these fixes to get your freezer freezing again.
LG Ice Maker Not Making Ice
Does your ice maker fail to make cubed or crushed ice, but still dispenses water? Try these fixes first so you can reset your machine and get back to chillin'.
LG Refrigerator Making Knocking Noise
Is the fridge auditioning to be a drummer? Is it a strange rhythm? Let's see if we can fix it and quiet the drums.
LG Refrigerator Not Cooling
What to do when your LG fridge stops cooling, but the light's still on? Try these fixes first.
LG Refrigerator Leaking Water
Is your LG fridge making puddles? Wet food inside? Let's walk through the causes and fixes.
LG Refrigerator Compressor Will Not Run
Is the compressor dead on your LG refrigerator? Let's try to get you humming again.
LG Refrigerator Will Not Dispense Water
You press the paddle with your glass, but nothing comes out. Maybe you get ice but no water. Let's get you flowing again.
LG Refrigerator Making Humming Noise
Is Your LG refrigerator humming, but you're unsure of the tune? Let's see if we can Quiet your concerns.
LG Refrigerator Door Not Closing
Is the door popping open on your LG Refrigerator? Will it not close correctly? Let's look at some causes and solutions.
LG Refrigerator Tripping GFCI
Is your fridge plugged into a GFCI-protected outlet? Is it losing its cool because it loses its power? Let's look at solutions!
LG Refrigerator Not Cooling But Freezer Works
Your LG refrigerator's freezer is fine, but the fresh food compartment (refrigerator section) isn't cooling. Let's work on keeping the fresh food fresh!
LG Refrigerator Freezes Food
Your LG Refrigerator is going beyond refrigerating your food in the fresh food compartment. It's freezing it! Let's walk through some causes and solutions.
Related Refrigerator Problems
Refrigerator Compressor Not Running
Has your refrigerator lost its cold? Is the compressor running while power is on? Follow these fixes to get your fridge's most important component working again.
Refrigerator Compressor Running but Not Cooling
Refrigerator Light Flickering
Are your fridge LEDs blinking or flashing? Is your door light flickering? Follow these fixes to resolve the light.
Does your fridge keep tripping the GFCI or circuit breaker? Whether it trips immediately or after a few hours, follow this fixes to get your refrigerator working again.
Fridge Not Cooling But Freezer Works
Is your fridge warm but the freezer is cold? Maybe the refrigerator isn't cold enough? Follow these fixes to get your refrigerator cooling again.
Is your fridge making intermittent knocking sounds, clunking, or banging sounds? Sounds like your fridge wants to be a musician! Follow these fixes to return your refrigerator to working its day job.
Ice Maker Leaking
If your ice maker leaks fluid, follow this problem page so you can get back to chillin.
Freezer Ice Building Up
Is your freezer compartment full of ice cubes? Are the shelves coated in powdered snow or ice crystals? Follow these fixes to defrost your freezer.
Ice Maker Not Dispensing Ice
If your ice maker isn't dispening ice, follow this problem page so you can get back to chillin.
Is your fridge cold but the freezer compartment is warm? Follow these fixes to get your freezer freezing again.
Is a pool of water forming underneath, inside, or behind your fridge? Follow these fixes to stop your refrigerator or freezer from leaking.
Is your fridge door not closing properly? Will food not stay cold because of a seal issue? Follow these fixes to get your food cold again.
Freezer Not Freezing Ice Cream
Is your freezer cold, but not cold enough to make the ice cream solid? Try these fixes to drop your refrigerator temperature.
Refrigerator Makes Humming Noise
Is your refrigerator humming? Does it hum constantly, or stop frequently? Follow this fixes to discover what's going on with your fridge.
Ice Maker Won't Stop Making Ice
Is your ice maker running? Is it uncontrollably overfilling with ice? Read this troubleshooting guide to catch and stop the ice before you're underwater!
Refrigerator Has Freezer Leaking Water Into Fridge
The Freezer is dripping into the fridge. What a mess! Let's get the leak stopped and things flowing normally.
Ice Maker Only Crushing Ice
If your ice maker is only crushing ice and not dispensing cubes, follow this problem page so you can get back to chillin.
Ice Maker Making Hollow, Small, or Mushy Ice Cubes
Are your ice cubes small, hollow, or mushy? Does your ice maker usually make solid ice cubes? Follow these fixes and get consistent ice again.
Refrigerator Won't Dispense Water
If your fridge isn't dispensing water while the ice maker dispenses ice, follow these fixes to get your water flowing again.
Refrigerator Sounds and Possible Causes
Here's a list of sounds or noises you might hear and some common causes.
Ice Maker Making Cloudy Ice Cubes
Is your ice cloudy? Are there specks of dirt or debris in your ice cubes? Follow the fixes below to start making clean and clear ice again.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
LG in-door icemaker won't dump ice into the bin
LG Refrigerator LFX28978**
Why is my refrigerator not cooling?
LG Refrigerator
What are the 3 flashes of green light on back of LG fridge?
LG Refrigerator
starts to blink 6 times on the led light
LG Refrigerator
LG refrigerator LFXS28968S won't drop ice into bucket
LG Refrigerator LFXS28968*
Error code rf and e
LG Refrigerator
