Nintendo Wii U GamePad Won't Charge
Steven Chiu and 2 contributors
Last updated on
Causes
Power issues can sometimes be caused by an AC adapter that needs to be reset. Unplug the adapter from both the console and the wall outlet. Wait 90 seconds - it will take at least this long for the adapter to fully reset. Plug the AC adapter back into the Wii U GamePad and wall outlet.
If this did not work, use a different charger.
2
The GamePad might not be getting a clean connection with the AC adapter. Check to see if the port is clean. Does a charger sit flush against the bottom edge? If it sits at an angle or has a loose fit, the port itself may be clogged. Use a flashlight to inspect.
  • Removing debris from a charging port can be a bit tricky due to its narrow gaps. Use an air duster and a toothpick shaved to fit to avoid damaging the port.
  • Other non-conductive tools can be used in place of a toothpick, but avoid inserting anything metal into the port.
3
If the charger works and the charging port is clean, it is likely the battery can't hold a charge, especially if the GamePad won't turn on. Consider replacing the battery.
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
123
All Time:
740
