We've identified your zipper:
You have a two-way plastic tooth zipper.
Checklist:
- Two zipper sliders.
- Plastic teeth.
- The zipper may be labeled "vislon."
- One end has a zipper stop, the other end opens.
- This is a tail-to-tail, two-way zipper, meaning that if you were to slide the zipper sliders together, the bottom or "tail" of each slider would meet.
Two-way Plastic Tooth Zipper Front
Two-way Plastic Tooth Zipper Back
What's wrong with my zipper?
Diagnose issues with your zipper using our guide: Plastic Tooth Zipper Issue Diagnosis
I need a replacement zipper.
Before you can get a replacement zipper, you need to determine your zipper size and pull type. Check out our Plastic Tooth Zipper Size page for instructions on determining your zipper size and pull type.
This is not my zipper.
If this is not your zipper, try again by starting our identification process over, or contact Patagonia Customer Service.
0 Comments
