AirPort/Bluetooth Board
4 Answers 6 Score |
What is the maximum RAM possible? |
17 Answers 2 Score |
Anyone added an SSD? |
1 Answer 6 Score |
Upgrade from i5 to i7 CPU |
1 Answer 1 Score |
Fan Not Working - How do I troubleshoot? |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A1347 (EMC 2570 Macmini6,1) 2.5 GHz (Dual i5), A1347 (EMC 2570 Macmini6,2) 2.3 GHz (Quad i7), A1347 (EMC 2570 Macmini6,2) 2.6 GHz (Quad i7)
Upgrades
You can cost-effectively upgrade a number of components in the Mac mini Late 2012.
- Memory: If your Mac mini is still running with only the stock RAM, upgrading will provide a dramatic performance boost at minimal cost. Upgrading to the maximum of 16 GB (two 8 GB modules) is simple and provides unmatched performance.
- Hard Drive: A 500 GB hard drive came standard with the late 2012 Mac mini. You can upgrade the drive up to 2 TB to expand your storage.
- Dual Hard Drives: The 2012 Mac mini has a second SATA socket on its logic board and plenty of room to install a second 2.5" hard drive. By installing a second drive you can greatly expand your storage capabilities or even install a solid state drive for lightning fast boot times.
Technical Specs
Measurements:
- Height: 1.4 inches (3.6 cm)
- Width: 7.7 inches (19.7 cm)
- Depth: 7.7 inches (19.7 cm)
- Weight: 2.7 pounds (1.22 kg)
Processor:
- 2.5 GHz dual-core Intel Core i5 (Turbo Boost up to 3.1 GHz) with 3 MB L3 cache or 2.3 GHz or 2.6 GHz quad-core Intel Core i7 (Turbo Boost up to 3.3 GHz or 3.6 GHz) with 6 MB L3 cache
Memory:
- 4 GB (two 2 GB) of 1600 MHz DDR3 memory
- Configurable to 8 GB or 16 GB
Storage:
- 500 GB or 1 TB (5400-rpm) hard drive
- Configurable to a 256 GB solid-state drive or 1 TB Fusion Drive.
Graphics:
- Intel HD Graphics 4000
- Support for up to two displays at 2560 by 1600 pixels
- Thunderbolt digital video output
- HDMI video output Support for 1080p resolution at up to 60Hz
Audio:
- Audio line in minijack (digital/analog)
- Audio line out/headphone minijack (digital/analog)
- HDMI port supports multichannel audio output
- Support for Apple iPhone headset with microphone
- Built-in speaker
Ports:
- Thunderbolt port (up to 10 Gbps)
- FireWire 800 port (up to 800 Mbps)
- Four USB 3 ports (up to 5 Gbps)
- HDMI port
- SDXC card slot
- Gigabit Ethernet port
- Audio in/out
Wireless Connectivity:
- 802.11n Wi-Fi
- Bluetooth 4.0
