Introduction
Replace a broken brake caliper or upgrade to bigger calipers for increased braking performance.
Removing the caliper requires disconnecting the brake hose, which will lead to losing brake fluid. When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
Jack up the front of the car and place it on jack stands.
Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
Pull the front wheel off the wheel lugs and set it aside.
Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
Detach the brake hose and remove the brake caliper.
