Apple IIc IC Chips Replacement
Josiah
Josiah and 4 other contributors
Last updated on May 11, 2020
20 - 25 minutes
Moderate
Introduction
Go to step 1
This guide will help you re-seat or replace the IC chips on the computer's mother board. The IC chips, or Integrated Circuit chips, are used to perform various vital functions on the computer. Chips coming unseated or going bad is a common problem with the Apple II series and is easily fixed or replaced. Re-seating your chips will helpful if you are having trouble running your computer.
iFixit earns commission when you buy through these links.
  1. Apple IIc IC Chips Replacement, Disassembling Apple IIc Cover: step 1, image 1 of 2 Apple IIc IC Chips Replacement, Disassembling Apple IIc Cover: step 1, image 2 of 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc IC Chips Replacement: step 2, image 1 of 2 Apple IIc IC Chips Replacement: step 2, image 2 of 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc IC Chips Replacement: step 3, image 1 of 2 Apple IIc IC Chips Replacement: step 3, image 2 of 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc IC Chips Replacement: step 4, image 1 of 2 Apple IIc IC Chips Replacement: step 4, image 2 of 2
    • Lift the handle straight up to remove.
  5. Apple IIc IC Chips Replacement, Keyboard: step 5, image 1 of 2 Apple IIc IC Chips Replacement, Keyboard: step 5, image 2 of 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc IC Chips Replacement, Floppy Drive: step 6, image 1 of 2 Apple IIc IC Chips Replacement, Floppy Drive: step 6, image 2 of 2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Apple IIc IC Chips Replacement: step 7, image 1 of 3 Apple IIc IC Chips Replacement: step 7, image 2 of 3 Apple IIc IC Chips Replacement: step 7, image 3 of 3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Apple IIc IC Chips Replacement: step 8, image 1 of 2 Apple IIc IC Chips Replacement: step 8, image 2 of 2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Apple IIc IC Chips Replacement: step 9, image 1 of 2 Apple IIc IC Chips Replacement: step 9, image 2 of 2
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Apple IIc IC Chips Replacement: step 10, image 1 of 2 Apple IIc IC Chips Replacement: step 10, image 2 of 2
    • Lift the floppy drive straight up to remove.
  11. Apple IIc IC Chips Replacement, IC Chips: step 11, image 1 of 3 Apple IIc IC Chips Replacement, IC Chips: step 11, image 2 of 3 Apple IIc IC Chips Replacement, IC Chips: step 11, image 3 of 3
    • Use the plastic opening tools to carefully lever the IC chips out of the holder. Gently lever one end and then the other to lift it out of the chip holder.
    • Do not force IC chips out! Pins are very fragile and can easily bend or break.
9 other people completed this guide.
Josiah
658 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
13 Guides authored
One Comment
What are the 4 round black things shown in the photos in Step 1 and Step 6? (No explanation is given.)
James Wages - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 14
All Time: 6,866
