Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement
  1. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: step 1, image 1 of 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: step 1, image 2 of 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 2, image 1 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 2, image 2 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 2, image 3 of 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 3, image 1 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 3, image 2 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 3, image 3 of 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: step 4, image 1 of 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: step 4, image 2 of 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 5, image 1 of 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Back Cover: step 6, image 1 of 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 7, image 1 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 7, image 2 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 7, image 3 of 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 8, image 1 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 8, image 2 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Button Pad and Battery Terminal: step 9, image 1 of 1
    Buy
    • Use tweezers to remove the power button from the back case.
  10. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 10, image 1 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 10, image 2 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 10, image 3 of 3
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
  11. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: step 11, image 1 of 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: step 11, image 2 of 2
    • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  12. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 12, image 1 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 12, image 2 of 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: step 12, image 3 of 3
    • Use the spudger to lift the motherboard from the case.
David Faltemier
19 Reputation
5 Guides authored
Cal Poly, Team 1-2, Regan SU 2012 Member of Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,156
