Microsoft Surface Pro Charging Port Replacement
  1. Microsoft Surface Pro Charging Port Replacement, Display: step 1, image 1 of 1
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
  2. Microsoft Surface Pro Charging Port Replacement: step 2, image 1 of 2 Microsoft Surface Pro Charging Port Replacement: step 2, image 2 of 2
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
  3. Microsoft Surface Pro Charging Port Replacement: step 3, image 1 of 2 Microsoft Surface Pro Charging Port Replacement: step 3, image 2 of 2
    • Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display, disconnect the three display cables.
  4. Microsoft Surface Pro Charging Port Replacement: step 4, image 1 of 1
    • Remove the display.
  5. Microsoft Surface Pro Charging Port Replacement, Charging Port: step 5, image 1 of 2 Microsoft Surface Pro Charging Port Replacement, Charging Port: step 5, image 2 of 2
    • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
  6. Microsoft Surface Pro Charging Port Replacement: step 6, image 1 of 1
    • Use the plastic opening tool or fingers to pry out the front camera.
  7. Microsoft Surface Pro Charging Port Replacement: step 7, image 1 of 1
    • Lift the outside panel from the Surface Pro
  8. Microsoft Surface Pro Charging Port Replacement: step 8, image 1 of 2 Microsoft Surface Pro Charging Port Replacement: step 8, image 2 of 2
    • Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
  9. Microsoft Surface Pro Charging Port Replacement: step 9, image 1 of 1
    • Pull out left and right metal panels with hands
  10. Microsoft Surface Pro Charging Port Replacement: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Pull out the orange charging port strip using tweezers
  11. Microsoft Surface Pro Charging Port Replacement: step 11, image 1 of 1
    • Unscrew the two T5 torx screws located on each side of the charging port.
  12. Microsoft Surface Pro Charging Port Replacement: step 12, image 1 of 1
    • Once you have unscrewed the charging port, you can gently pull it out with your hands.
5 other people completed this guide.
Jonathan Choi
1,005 Reputation
4 Guides authored
Cal Poly, Team 8-20, Regan Fall 2013 Member of Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Members
16 Guides authored
4 Comments
Where do you get a replacement charging port at?
Evil Robot - Reply
Agree where can you get the port?
J-M. M. - Reply
Same instructions for changing the port on a surface pro 2?
Robert - Reply
I followed the guide for Surface 5, inside it's very different, but the guide gave me confidence that's its possible. And In the end success. I've found for socket just on aliexpress.
Виктор X - Reply
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 195
All Time: 28,352
