Reset Bluetooth Module or Factory Reset All Connected Apple Devices
Video Overview
  1. Reset Bluetooth Module or Factory Reset All Connected Apple Devices, Reset Bluetooth Module or Factory Reset All Connected Apple Devices: step 1, image 1 of 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices, Reset Bluetooth Module or Factory Reset All Connected Apple Devices: step 1, image 2 of 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices, Reset Bluetooth Module or Factory Reset All Connected Apple Devices: step 1, image 3 of 3
    • First enable the Bluetooth Icon in the Menu Bar
    • Click the Launchpad icon in the Dock, and then navigate to "System Preferences" - "Bluetooth".
    • Click the checkbox next to “Show Bluetooth in Menu Bar” to enable it.
  2. Reset Bluetooth Module or Factory Reset All Connected Apple Devices: step 2, image 1 of 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices: step 2, image 2 of 3 Reset Bluetooth Module or Factory Reset All Connected Apple Devices: step 2, image 3 of 3
    • Press and hold the Shift + Option keys on your Mac's keyboard and click the Bluetooth symbol in the top-right corner of the macOS menu bar.
    • Locate the revealed Debug submenu and hover your mouse cursor over it.
    • If you have problem with a connected Bluetooth device you can reset the Bluetooth module entirely from the Debug menu. This will wipe the Bluetooth configuration, reset the Bluetooth hardware, and disconnect any connected Bluetooth devices.
    • If you want to fix a problem with connected Apple device then try the second menu. It works only the device is connected an only for Apple devices!
3 other people completed this guide.
ZFix
191,647 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,501 Guides authored
5 Comments
Hi, wenn ich Shift drücke und das BT Symbol klicke kommt das normale Menü (BT An/Aus, Geräte-Übersicht, Einstellungen), wenn ich Opt (mit oder ohne Shift) drücke und auf das BT Symbol klicke kommt ein erweitertes Menü (BT An/Aus, Name, Adresse, Version, Geräte-Details, Einstellungen), aber einen Debug-Eintrag gibt es unter keinen Umständen (MacOS 12.2.1).
Wo ist das Debug Menü?
Martin Hans - Reply
brauche ebenfalls eine antwort!
Hias Major -
Ab macOS Monterey und später geht das so:
Öffnen Sie die Suche (CMD+Spacebar drücken)
Geben Sie Terminal in das Suchfeld ein und öffnen Sie das Terminal
Geben Sie folgenden Befehl in die Kommandozeile ein: sudo pkill bluetoothd
Drücken Sie Enter, geben Sie das Passwort des Administrator-Kontos ein.
Starten Sie den Mac neu
Hinweis: Für diesen Trick benötigen Sie Administratorrechte.
Gernot Schauer - Reply
Bluetooth auf MacBook Pro 2015; Monterey schaltet sich nicht vollständig ein. Es kann nicht einmal die Bluetooth-Einstellungen öffnen. Kürzlich habe ich einmal auf Software aktualisieren geklickt, nach dem Update konnte kurzzeitig eine Verbindung hergestellt werden, dann ging es wieder von alleine. Ich habe mehrmals versucht, neu zu starten und sogar das Betriebssystem neu zu installieren, aber es hat nicht geholfen.
Kahuna Kort`eze - Reply
Bluetooth on MacBook Pro 2015; Monterey does not turn on completely. It cannot even open Bluetooth preferences.
Recently, one time I clicked update software, after the update it was able to connect for a short while, then it went off on its own again.
I have tried to restart multiple times and even re-installed the OS but it does not help.
Past 24 Hours: 31
Past 7 Days: 268
Past 30 Days: 1,308
All Time: 36,299
