Dell Inspiron 15 7579 Back Panel Replacement
  1. Dell Inspiron 15 7579 Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Back Panel Replacement: step 2, image 1 of 2 Dell Inspiron 15 7579 Back Panel Replacement: step 2, image 2 of 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Inaki Madrigal
760 Reputation
6 Guides authored
Cal Poly, Team S24-G9, Maness Spring 2018 Member of Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,131
