Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement
  1. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Unfasten the back cover: step 2, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Unfasten the back cover: step 2, image 2 of 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Insert an opening pick: step 3, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Insert an opening pick: step 3, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Insert an opening pick: step 3, image 3 of 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Angle the opening pick: step 4, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Angle the opening pick: step 4, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Angle the opening pick: step 4, image 3 of 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Free the bottom right corner: step 5, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Free the bottom right corner: step 5, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Free the bottom right corner: step 5, image 3 of 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Free the front edge: step 6, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Free the front edge: step 6, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Free the front edge: step 6, image 3 of 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Remove the back cover: step 7, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Remove the back cover: step 7, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Remove the back cover: step 7, image 3 of 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Disconnect the battery: step 8, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Disconnect the battery: step 8, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Disconnect the battery: step 8, image 3 of 3
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Disconnect the right fan cable: step 9, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Disconnect the right fan cable: step 9, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Disconnect the right fan cable: step 9, image 3 of 3
    • The right fan will be on your left-hand side when working on the laptop, as it's laying upside down.
    • Push on alternating sides of the right fan cable connector with the tip of a spudger to "walk" it out of its socket.
  10. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Unfasten the right fan: step 10, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Unfasten the right fan: step 10, image 2 of 2
    Tool used on this step:
    Buy
    • Use a Phillips screwdriver to remove the two 5.3 mm‑long screws securing the right fan.
    • The fan screws may be covered with stickers. Pierce through them with your screwdriver or use tweezers to remove them.
  11. Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Remove the right fan: step 11, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Right Fan Replacement, Remove the right fan: step 11, image 2 of 2
    • Remove the right fan.
Spencer Day
58,680 Reputation
430 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,529 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 23
All Time: 414
