Repair and troubleshooting information for GE brand dishwashers.
12 Questions View all
Can't adjust wash time on panel
My GE Profile Dishwasher PDW9980N00SS control panel is stuck on wash time over 100 minutes and it won't let me adjust it. Is the control panel something that a lay person can change or is it a professional's job?
Add a comment
1 Answer
Chosen Solution
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Score 1
Add a comment
Add your answer
redfoxfan57 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 316
