Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
743 Questions View all
The CD won't recognize any discs and it won't eject
My MacBook Pro 13' Early 2011, used to work fine, but now I inserted a CD and it didn't even recognize it, and as it doesn't recognize it there is no way to eject it.
I have tried holding down the trackpad while restarting the MBP but still keeps the disc inside and is not recognizing the disc nor ejecting it.
I have tried with command E, I have tried with mac DVD player, I have tried with iTunes and nothing seems to work.
I take care of my laptop really well, so I didn't hit it with anything or bumped the laptop at all, it only sits on my heat reduction pad on my desk and I take care of it really well. Some days ago when I inserted a disk it used to work fine but now I have this problem and nothing seems to work.
Any new fresh, step by step ideas on how to solve my problem? I would be greatly appreciated please help!!
Score 1
Add a comment
Chosen Solution
i experienced this kind of problem,try a piece of paper or cardboard as thick as 1mm.x2cm.wide x 15cm.long at foremost end of it place a double tape as thick as 1mm. x 1.5cm.L x 1.5cm W, or you can fold a clear tape to make it double tape but be sure that pressed and you stick it well on paper,insert it on your disc drive as much as 4 to 5 cm. at center and lift up a little,back to center then move in out motion for a small distance then if you feel a load on it pull it out slowly,this was a stupid idea but it works,hope it can help your problem solve.
have nice day
xerxes
Score 2
1 Comment:
i didn't think this would actually work....but it did! thank you!
by
Add a comment
I just tried this. It worked! Thank you so much! Never though a piece of paper and tape would do the trick, but it worked like magic. I had tried everything and was so frustrated, I was ready to unscrew the entire laptop or even splice it open.
Add a comment
Add your answer
Rich will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 10,943
