The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 Questions View all
I can't see any picture on my Display.
I can't see any search-picture on my display, the display itself may be o.k., because when I use the menu-button I See the menu on the display. When I start ! see the informations on the display. What can I do?
Add a comment
1 Answer
Most Helpful Answer
newsforpeter, this can be caused by a bad CCD on your lens. Check the ribbon cables and make sure they are properly inserted. Also check for corrosion and debris damage. If all that looks ok you may need to consider either a new CCD or a complete lens.
Score 2
Add a comment
Add your answer
newsforpeter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 259
