The first generation Audi A4 debuted in October 1994. The 1995-2001 A4 was built on the Volkswagen B5 platform.
7 Questions View all
Window in left front door lowers but can't be raised?
Audi A4 1994 left front door window goes perfectly down but cannot be closed any more. Possible there is a wire broken in the rubber tube behind door and car body. But there are a lot of wires there. Anyone known to this problem?
Score -1
Add a comment
Well what I realised on my 97 Audi Cabriolet V6 after spending hours trying to close window I opened on evening I bought car..
I narrowed it down to the MAIN switch control in drivers door. So i unclipped each button from the main controller switch on drivers side off and just changed them around.. i.e.. So rear window switches actually controls front and visa versa..
Add a comment
I had the same problem and what I found was if you put your key in the driver door, turn key to lock position and hold in lock position until the window rolls up
Add a comment
Add your answer
Ad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,011
