Repair information for PowerBook G3 laptops from Apple.
85 Questions View all
I installed OS 10.4.11, now my DVD drive won't work?
Want to install OS 9.2, but now my Pismo won't work with any DVD or combo drive I put in. System Profiler sees the drive, but the PB won't run the inserted disk. The DVD-ROM worked when I installed OS 10.4, seems to have stopped after that.
I think it may be that I did not install OS 9 drivers, starting over, will let you know. Thanks!
Score 1
3 Comments
Was the 10.4 a full retail version or from another machine? It can just be a coincidence that your optical drive died at that moment, or it can be a driver issue. Please provide more details on the DVD.
by
Did you install the OS9 drivers when you installed 10.4?
by
Tried re-installing 10.4.6, then used the combo update to 10.4.11. I am at a loss. It seems the DVD drive will read DVDs, but not CDs? Says this computer does not recognize this disk, or something. Hence, I cannot install OS 9.2 from the CD. Could it be the order I have done this successfuly before, and can't figure what I did this time so it doesn't work on this Pismo.
by
Add a comment
1 Answer
Chosen Solution
Hi, When I had a problem after installing 10.4.11 Apple had me reinstall the 10.4.11 combo updater. Cured the problem--don't know if it will cure yours but worth a try. (no cost) I am including a link to the updater for you. Ralph.
http://support.apple.com/kb/DL170
Score 3
2 Comments:
Hi, The best I can do for you now is to provide the link for the Apple guide on installing OS 9. Ralph
http://manuals.info.apple.com/en_US/MACO...
by
Add a comment
Add your answer
hermanski3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,153
