My Samsung Galaxy Tab 4's Screen Is Not Working..
My Tablet is on and the screen is just black with with blurry lines but I haven't been able to use the tablet for almost a year and it was new.
You can try a hard reset this will take you back to new all your data and apps will be lost but at least you should have a working tablet
http://www.technipages.com/galaxy-tab-4-...
This is a walk through on haw to do it. Good Luck
If it’s almost a year, and it was new, it will be covered under a warrenty
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 5,354
3 Comments
It didn't work :( the screen lights up but there's nothing on the screen except the white lines and black everywhere else.
by Jessica Goode
same problem comes in my samsung tab..so what you do??
by Sandhya Sharma
If you can open and remove the back cover of the tablet (or ask a tech guy to open it), check the two cable connectors from the screen to the motherboard. One is the LCD and the other is the digitizer. I don't know which is which because I have seen them on tablets that were damages and disassembled. Maybe one of them is not well seated, so carefully press them down, and power the tablet on to check. You can do this without the back cover on and the battery reconnected.
by rayramirez
