The Dell Inspiron 15-7537 is a 15.6" touchscreen laptop with an i5 core processor.
22 Questions View all
Why pre-installed HDD & 6GB of RAM?
For some weird reason, my 7537 came with 6GB of RAM. Do you think I can upgrade it to 8GBx2 = 16GBs of rum? Is there any DDR or BUS limitations?
Also, mine came with a 500GB 5400RPM HDD. Do you think installing a 7200RPM will be a problem? What about hybrid SSHD? Will that be a problem?
my cpu: http://s22.postimg.org/oehic7g9d/cpu.png
my ram: http://s22.postimg.org/tomh3i0i9/ram.png
Add a comment
1 Answer
Chosen Solution
I own a Core i7 version with 16GB RAM with a 1TB 5400rpm hybrid drive. But the chipset is the same as yours.
So, there mustn't be any issue with a 2*8GB configuration, hybrid drive or a 7200rpm drive. You can install all of this by yourself. Just remove the bottom panel by removing the 6 screws (2 are fixed to the plate) to expose the HDD and the RAM modules. Install and then close.
Score 1
Add a comment
Add your answer
musavvir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 160
