ZTE Boost MAX N9520 boasts a 5.7-inch HD IPS Display with 4G LTE and Android 4.1.
59 Questions View all
Why won't my external speaker work?
External speaker won't work. Internal work's fine. I can hear music with ear buds, I can hear phone conversation as long as it's not on speaker. My ringer doesn't work as well. Hasn't had any water damage. I did have a cracked screen but it was just replaced profesprofessionally.
2 Comments
Hi,
How long since it was repaired? Was the ringer function working when you got it back from repair? Does the repairer give a warranty on his work? If it has not worked since his repair (how often do you use the loudspeaker function) it seems very coincidental, contact the repairer and ask. The ringer function (not vibrate) uses the loudspeaker so if it is loose or faulty that is probably why both don't work
by
Why no one can hear me but I contacted hear them
by
Add a comment
1 Answer
Chosen Solution
Hi Faith Randall,
Have you checked the volume setting for the loudspeaker?
Go to :
Menu > Settings > Sound > tap Volumes > slide volume control for Loudspeaker to desired volume.
Score 3
1 Comment:
Yes I did check the volume
by
Add a comment
Add your answer
mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,353
