The Canon A2300 is a 16 mega pixel digital camera released February 2012.
12 Questions View all
Why does my camera keep coming on the screen 'memory card locked'
I have charged the battery inserted the memory card correctly switch camera on press button to take photo and the camera bleeps about 6 times and won't take photo won't deleat photos
Score -1
Add a comment
1 Answer
Chosen Solution
SD cards have a notch on the left side edge (as seen from the front of the card) with a small tab. When this tab is in the LOCK position, a sensor switch in the camera tells the camera that the card should not be written to, i.e. the card is locked. This feature can be used to avoid inadvertently deleting pictures from a card, or inadvertently formatting a card (a delete or format command counts as a write) but it also makes it impossible to save new pictures to the card.
  • Remove the SD card from the camera. Check the position of the locking tab and make sure it is not in the LOCK position. If it is, use your fingernail to shift the tab upward away from the LOCK position. Reinsert the card, and try again.
  • If you are positively sure that the locking tab is not in the LOCK position, and the camera continues to tell you the card is locked, the camera's sensor switch might be stuck.
  • Sometimes, the locking tab pops out of its notch and goes missing. If you see the notch where the locking tab should be, but the locking tab itself is absent, you can tape over the notch with a tiny piece of thin adhesive tape. Be careful, if this is not done cleanly or the tape is too thick, the SD card might get stuck in the slot and you'll have difficulty getting it to eject.
  • Inserting and releasing the card a few times, thereby jogging the sensor switch, may clear the problem.
  • As a last resort, you can give the SD card slot a blast of compressed air from a can. Be careful because the "air" from the can might cool down the card slot to the point of causing condensation, so wait a while before turning the camera on again.
  • If the problem refuses to clear, have the camera looked at by someone knowledgeable.
Score 2
Add a comment
Add your answer
Janet hookway will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 145
