The Dell Latitude E6410 is a 14" laptop released by Dell.
18 Questions View all
Blinking cap locks and won't boot
So being the dummy I am, I spilled some juice onto my laptop. It went though the keyboard and on to the area where my ram is( I know this because there was something sticky in just that part). the power light comes on and so does the fan so I know it's not a power thing. The middle caps lock flashes while the numb and scroll stay solid. I tried replacing the ram but that did nothing. There was also a few times where the dell logo popped up and loaded but then these crazy colored lines appeard on the screen and that was it. Please help!
1 Comment
Add a comment
1 Answer
Chosen Solution
Hi,
The colored line is a bad connection between mainboard to screen ( broken or ripped cable, dirt, ...)
Or a failing GPU.
in case of juice spill , you need to clean the main board immediately with isopropyl alcohol. is it long ago the spill?
try to clean it anyway... but do it propperly , use enough of isopropyl ( you can buy this at a drugstore...)
clean every connection.
This is a good time to clean the fan en colling pads as well. check transistors an capicitators for leak also check the chips on the mainboard. clean the ram would help but i think it will be to late , try with other ram after cleaning.
Most of the time the keyboard is dead to.. replace this as well.
Kind regards,
kevin
2 Comments:
Do you mean clean the motherboard? This all happened last night.
by
indeed i mean to open the laptop and clean the components at the motherboard.
if you spill some liquid it will go to the motherboard...
by
Add a comment
Add your answer
Tariq G will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 9,103
